Results 1 to 7 of 7
    Mar 2006
    ireland
    14
    Quattro Sport feelin Sluggish
    Please bear in mind that I'm no mechanic, so wouldn't really know my way around the full workings of the car..
    I've got an 03 A4 Quattro Sport, it feels sluggish, like there is something holding it back. It is not freewheeling like my a4 TDI, if I go to move off and engage the clutch it slows to a stop. I've had a mechanic check brakes and they are not sticking..
    Any thoughts on what else it could be? Any ideas for what I should be looking for or researching?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Knowing what engine it is will help too
    Mar 2006
    ireland
    14
    Its 3.0L v6
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    Not much to go on but here's some suggestions
    Fuel/air isssue - when were the filters changed, last service?
    Egr clogged up (do theses engines have them????)
    Any number of engine management sensors, MAF, MAP etc - get a fault scan done
    Injector issues - get a scan done
    Driveshaft/gearbox issues - unlikely
    A4 Avant 1.9 TDi Sport GmbH
    Mar 2006
    ireland
    14
    Doodah, thanks for the points
    I was thinking it was more mechanical, more along the lines of driveshaft etc. Simply because it drags when in neutral or clutch is engaged, would this not rule out filters, sensors etc?
    I will put it on computer and see what codes shes throwing up
    Sep 2012
    Swindon
    371
    If it's doing it in neutral then that does point to drivetrain issues. Maybe wheel bearings but I would've thought that would've been ruled out when your mechanic checked for sticking brakes? If it was driveshaft/gearbox then I would think there would be more obvious issues like grinding gears or wobbles/knocking when driving. Maybe the clutch isn't properly disengaging but again, I would think this would come with gear change issues too.
    It does point to sticking brakes, though. How well do you know your mechanic? For a diy check, go for a drive and try to coast to a stop then, with the back of your hand, feel for excessive heat at each wheel. Another thought, does it still drag if you turn the ignition off (on a straight empty road only) because there could be a servo problem, gently squeezing the brakes all the time. This wouldn't reveal itself on a ramp because it's likely the engine would be off when checking for a non-returning piston.
    I'm no mechanic but I am paid to fix aircraft for a living so just thinking out loud
    pauldazzle's Avatar
    Cardiff
    634
    Get it on diagnostics to eliminate sensors problems as a cause, there's bound to be a member with VCDS near you to help you out.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat, 165bhp remap, EGR delete, K&N panel, Dunlop SP Sport Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
  1. Underside of Audi A3 Quattro Sport 3.2
    By Rozz in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th December 2003, 11:37
  2. 17" QUATTRO ALLOYS from A4 1.8T Quattro Sport
    By jxm96c in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th November 2003, 17:31
  3. A3 Quattro Sport Tuning
    By ANDYTQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th November 2003, 15:42
  4. A4 avant quattro sport
    By Bryan in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th October 2003, 07:59
  5. A6 Avant 2.5tdi quattro sport Tiptronic
    By jyeoman in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 24th August 2003, 16:39
