Sky InsuranceVolks Autos
Results 1 to 22 of 22
    czm
    Feb 2013
    209
    F$€¥¥* Pinch Bolt
    So yesterday tried fitting coilovers on my b6 avant. As I have had issues with pinch bolts on other cars I thought I would tackle them first. OMFG!!!!!!!
    what a complete arse they are.
    Rung the head of but there was some movement of the thread so thought cool not seized, this will be easy!!
    oohhhh no, those things are soooo tight.
    lomg story short, got it out half way after 5hours of lump hammers, air chisels and blood sweat and tears. I gave up and going to limp it to my local garage in the morning.
    Seriously, what a PITA they are.
    2004 BEX 1.8T Silver Avant - RTECH Stage 1 Remap - 211Bhp/236ft Torque
    TEIN Super Street Coilovers - BlueFlame Catback with 4'' Slashed/Rolled Tips
    Pipercross AirFilter- RS6 18'' OEM's - 225.35.15 Falken 452
    Jan 2013
    Bath
    68
    I had a little look at mine as was thinking of fitting new springs... they look like they'll be alright but I'm sure that's just them being deceiving. Any thoughts?
    4th set of a wheels in a year
    Jul 2012
    merthyr, south wales
    425
    Visit krisavant's Instagram Channel
    Not even worth the hassle, read so many horror stories about these bolts.
    Took mine to the garage and paid £90 to have b5 perches put on.
    To be fair they smothered the pinch bolts with copper grease when put back in, so must have been a pain.
    Mar 2007
    salford gtr manchester
    556
    why do you need to remove the pinch bolt I have replaced loads of springs on a4s and a6s and never needed to remove the pinch bolt . I just take the whole leg out with the aluminium top plate attached no need then to remove the pinch bolt
    czm
    Feb 2013
    209
    Quote Originally Posted by yendall24 View Post
    You don't, I just though that I would be clever and while I was in there I would change them in case I need to replace the control arms ect in the future.
    Serious error, don't even go near them unless you HAVE to
    czm
    Feb 2013
    209
    Quote Originally Posted by Steffgj View Post
    Don't touch them unless you absolutely HAVE too.
    Mine looked cleaner than that.
    pauldazzle's Avatar
    Cardiff
    558
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat pipe, 165bhp remap, EGR delete, Dunlop SP Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    621
    Where was this guide when I needed it.
    This guy made it look piss easy.
    czm
    Feb 2013
    209
    That guide is no good for the b6,one the slots are on different sides (one front and one behind) and to the arm gets in the way so you can't undo the threaded left over out.
    Chris-Vspec's Avatar
    Mar 2013
    Verwood, Dorset
    247
    We have just lowered our car, did the same as mentioned above and took the whole leg out and left the pinch bolts in. Why make life difficult for yourself??
    maybe there should be a sticky on how to do the suspension without removing the pinch bolts, would save a lot of time and headaches for owners
    czm
    Feb 2013
    209
    Agreed Chris, what's so damm annoying is that I had no plans to touch it and just remove the whole leg like you did..... However I looked at the pinch bolt and thought, can't be that hard!!!!!!! Oooooooooo how wrong I was.
    Taking it to my local garage first thing in the morning, give them the headache.
    Mar 2008
    1,017
    you dont have to undo pinch bolt do it this way first pop of the center cap of your wheel then undo the hub nut then jack car up and remove wheel then undo brake cailper then undo the caliper carrier remove brake disc then undo track rod end then split the lower 2 ball joints then undo the lower bolt that holds the strut then the 3 bolts under the bonnet then hold the suspesion in place... once all this is undone then remove the hole unit then place spring clamps on spring and once you got some play in the springs undo the top nut and the spring will be able to be removed ....... i got it down to 2 hours this way once the unit it out maybe you might be able to have the pinch bolt pressed out if you got or no someone with a press
    Apr 2012
    N. Wales, LL22
    1,224
    undo bottom bolt, undo top bolts, use spring compressors, lift unit out, easy
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,071
    Yes, they are fun to remove.
    Coilovers can be fitted without removing the pinchbolt, however I needed to remove the pinch bolts on mine to replace the upper suspension arms (I had one dead ball joint).
    After many hours of trying different methods (air tools, vice, heat, drilling) the bolt was well and truly seized - I ended up purchasing a new suspension upright (was around £250).
    A local garage managed to remove the second pinch bolt, but charged £180 for the privelidge!
    I was actually thinking of widening the hole in the new upright slightly, but just opted to use plenty of copper grease and rest in the hope that I never actually need to remove it again!
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,727
    While I agree, it's not the worst thing in the world you could be doing. If you ever need to replace a top control arm you'll need them out so it's not a bad idea to get them out, and put new ones in with copper slip. My plan is to remove and regrease mine every 6 months now to stop them being evil again. It took 6 hours to remove the two bolts for us.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,730
    Quote Originally Posted by crazy88 View Post
    Admittedly it's somewhat easier, but I do that with my number plate light screws lol
    Oct 2012
    56
    How about putting in stainless steel replacements as well as copper grease once you've managed to get the old bolts out? Would save them corroding and they're a fairly standard bolt so shouldn't be hard to source stainless replacements I'd have thought.
    czm
    Feb 2013
    209
    Quote Originally Posted by A3_130 View Post
    Good idea.
    Drop it off at the garage this morning, just waiting on the dreaded phone call to tell me bad I screwed it up whenI was in my pinch bolt rage
    Andie0's Avatar
    Aug 2012
    487
    No need to take out punch boltt
    2004 audi a4 s line 1.8t bex 242bhp dynoed
    Mods: bsr optiflow kit, forge diverter valve, custom turbo back exhaust, custom 200 cell cat, DGR coilovers, forge tip, s3/tt 386cc injectors, boost gauge, revo stage 2, 12mm rear spacers, rear window extension spoiler
    To come: big brake setup... Getting there!!
    boats and hoesss, boats and hoesss
    czm
    Feb 2013
    209
    10 tonne press, removal of the complete arm and a special jig and its out!
    Interestingly the guy at my local indy said that the bolt is actually tapered by about 1mm (which he never knew and has done loads of them before) so going the way we were trying is virtually impossible and the further you go the tighter it gets!! The head rung so I was trying to use the thread to pull it out
    He said we were nuts to try and take it out and really not needed when changing the suspension which we knew but thought we would be clever – a very costly mistake but you live and learn!
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    621
    For me personally it was the fact that I started on it, I had to finish it.
    The best bit about it is the feeling you get once the fu**er comes out. That sense of relief is what it is about when it comes to these sort of jobs.
    Feb 2013
    Newcastle
    43
    Heat heat heat! only easy way, you will need to change the top arms though.
    If you're good at something, never do it for free.
  1. b5 perches and pinch bolts for b6
    By crazy88 in forum Parts Requests
    Last Post: 9th January 2014, 11:52
  2. Cant get pinch bolt out and wont turn (2.4 V6) - HELP please
    By V6 family guy in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th September 2011, 20:53
  3. Blow Torch, Pinch Bolt and air suspension dont mix
    By zjamiez in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 22nd May 2010, 18:48
  4. Pinch bolt my arse, more like ******* bolt!
    By AndyMac in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th September 2008, 23:43
  5. Advice on how to remove the top control arm pinch bolt..
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th May 2006, 19:06
