Badger5AH Fabrications
    May 2013
    10
    Seat height adjustment motors
    Hello
    I have an A4 cabriolet (2002 B6) with electric seats but seat height adjustment on the driver’s side only. Both the front and rear height adjustment motor assemblies have failed. The motors still work (I can hear them) but they are grinding away at nothing.
    I'm assuming that they have stripped a cog.
    I can't buy anything but the whole assemble from Audi (£245.50 each) and I can't find any second hand ones (presumably because they are flimsy as hell and fail)
    I am waiting for the arrival of the correct triple square socket to get the seat out and have a look at the assemblies, but they look like they come apart.
    My questions are:
    Are there any user serviceable parts in there?
    If so are they shared with any other motor assemblies which I might be able to get hold of?
    could I have the busted part fabricated?
    Has anyone taken one of these things apart?
    The part numbers are
    8E0 959 112 (fitted to right side of driver’s seat, moves rear of seat up and down) essential as my wife is 5 foot 2 and I am 6 foot 2
    7L0 959 762 or 7L0 959 762b (fitted to left side of driver’s seat, moves front of seat up and down) This one isn’t essential but would be nice to have
    Any help much appreciated
    May 2013
    10
    Further to the above. I've taken it out and it does come apart. The bit that is faulty is a small ferris wheel shaped plastic wheel which is driven by a worm gear.
    I don't know if any other VW/Audi motors share the same small plastic part though.
    May 2013
    10
    In the end I found a second hand one (for the right hand side motor which was the vital one) it was £120 though.
    I'm sure that the plastic wheel could be fabricated or cast with a little bit of time and patience, unfortunately I didn't have time to try and do this.
    It was fairly easy to fit. Took about 40 minutes.
  1. Electric Seat Height Adjustment.
    By fourcircle in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th December 2011, 13:07
  2. Drivers seat height adjustment - Problem
    By DaveA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th June 2011, 08:20
  3. S3 Electric Seat - Height Adjustment Not Working
    By imported_spuddie007 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th May 2006, 22:02
  4. Seat height adjustment.
    By S3BeemerBeater in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th April 2004, 09:14
  5. Headlight height adjustment
    By Gaunty in forum Volkswagen and other VAG
    Last Post: 22nd December 2003, 16:53
