Like Tree1Likes
  • 1 Post By AlexGSi2000
Thread: Cv boot gone can't get pinch bolt out
    Oct 2012
    389
    Oh joy of joys it's cv boot time, the drivers side has gone and despite which huffing and puffing i can't shift the pinch bolt up top it's seized big time.
    So how else can i get the shaft out of the hub, or remove the damn bolt, i haven't tried heat as i only have a basis plumbing type blow torch and i don't want to fry the upper joints either.
    ta
    ian
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,070
    If you remove the two lower ball joints on the suspension arms then it will give you enough maneuverability to get the shaft out.
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    245
    Hang fire with lower ball joints. You can disconnect at inner driveshaft. Held in place with splined bolts. You'll need to remove plastic trim where driveshaft goes from wheel to engine, and bell housing guard on inner driveshaft. Turn wheel to hard lock and you should be able to remove.
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    Oct 2012
    389
    i cant seem to access one of the guard bolts and then bloody downpipe is in the way it's a 1.9 diesel thats the culprit
    Jun 2012
    Teesside
    392
    You don't need to separate anything to remove the shaft, I have recently replaced my driveshaft, unbolt from the gearbox and undo shaft bolt, and its a bit fiddly but it will feed through past the suspension parts
    Mods done: interior: Light to dark conversion, To Do: Carbon trim, carpet to be replaced, rear window retrofit. Exterior: Resprayed in Skoda's Rallye Green, 18" RS4 reps fitted, xenons, LED sidelights/NumberPlate lights, B Pillars wrapped in carbon. To Do: Lowering 35mm all round, tints, Tuning: Yet to do exhaust/remap/ egr delete etc..
  1. rear boot Audi rings - where can I get a replacement for pre-facelift car?
    By Squirrelofdoom in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2013, 10:53
  2. Cant get pinch bolt out and wont turn (2.4 V6) - HELP please
    By V6 family guy in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th September 2011, 20:53
  3. How can i get 40 Bhp out of my 2.0fsi?
    By Huz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd May 2011, 11:13
  4. Can't get head bolts off my A3!!
    By samanthathepinkpanther in forum General Technical / How To
    Last Post: 1st October 2009, 19:27
  5. Can you get tuning boxes for SAME tractors??
    By smanning in forum Diesel forum
    Last Post: 17th July 2003, 09:55
