Results 1 to 9 of 9
    Feb 2013
    Bristol
    Climate control not functioning properly!
    Hi, I'm a newbie to the forum and recently purchased a 2004 B6 S4. When i bought the car, the weather was a little chilly and therefore I didn't get round to testing the climate control fully. It seems to work fine when I need to warm the cabin on chilly mornings but now the weather has finally decided to warm up a touch I thought I'd try it to on the LO setting. The first time I tried it, it seemed to work fine and there was plenty of cold air blowing into the cabin. However I have noticed that it doesn't always seem to work. Yesterday I turned it to LO and there was still warm air pumping out of the vents. It would appear that its intermittent as to when it wants to work properly!! Has anyone else experienced a similar problem?? I'm hoping a simple re-gas may sort this!! Thanks in advance!!
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    439
    Get vcds (vagcom) Hooked up to it. To scan for any faults just to Be sure.
    also due to the age of the car it might just need a re-gas. Maybe take it to somewhere that does air-con to get them to have a quick look.
    also welcome to the forum mate
    03 Mig blue 1.9tdi 130 saloon:- GMBH front, dark tints all round, fk coilovers,
    BMW TIGERCLAWS 19" 9j front + 10j rear, debadged rear. HIDs 6k, egr delete
    cominig soon:- votex rear,front end respray, parrot kit, remap, full paint correction
    Mar 2013
    Near Oxford
    405
    turn car on, pop bonnet, see if air con rad fan is spinning. If it isnt then chances are it needs a regas.
    Feb 2013
    Bristol
    I'll check the fan first and see. Failing that I have found a local car electrical specialist that does free air-con checks and give them a whirl! Hopefully a re-gas with fix it! Thanks for the advice chaps!!
    Feb 2013
    Bristol
    I've just fired the car up and switched on the climate control on the LO setting and the fan does kick in. However there is still only warm air coming from the vents.
    Mar 2013
    Near Oxford
    405
    strange, in the past I have used kwik fit for air con re gas, it's so simple they can't really cock it up
    Air Conditioning
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    is the econ light lit up ?
    Feb 2013
    Bristol
    No, even if I switch the Econ button to on it still doesn't make any difference. Just so as I'm not looking at the wrong radiator, can someone describe where the air-con rad and fan are on an S4? Thanks.
    kite's Avatar
    Oct 2007
    East Berks
    675
    You could have a flap motor stuck.
    Common problem.
    Try a search.
    A4 (b6) 2.5 TDi QS Saloon.
  1. Retrofit cruise control not functioning as intended
    By heeman10 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th March 2014, 22:49
  2. A3 8P Climate Control not working properly....
    By 210_MIH in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th January 2013, 09:33
  3. HELP - Fuel Meter on DIS not functioning Properly
    By fraz in forum TT/TT-S/TT-RS Forum
    Last Post: 25th November 2005, 23:17
  4. New Climate control unit, Fan not working
    By imported_Astwell in forum General Technical / How To
    Last Post: 27th January 2005, 20:39
  5. Climate Control not blowing very cold
    By jgrand in forum General Technical / How To
    Last Post: 15th July 2004, 13:56
