EM TuningAH Fabrications
Results 1 to 8 of 8
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,412
    Climate control observation
    Has anyone noticed that when climate control (CC) is on auto, when I put my windscreen washers on and hold so washers come on.......the CC boosts in fan speed and calms down after a few seconds when arms have finished their wipe action.
    Anyone else noticed?
    Mike
    Aug 2011
    151
    It's actually closing the vent while the washers operate.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,412
    Ahhh..........i was starting to think that I had a short somewhere.
    Just thought it was weird as the fan speed increases and can also be seen on the control panel..........suppose it is trying to protect the windscreen from the temp change
    Mike
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    521
    I noticed it too. It's the recirculating motor I thnk, trying to prevent washer fluid smell from entering the cabin.
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,722
    Does anyone elses climate control unit grunt away after they stop the car and remove the key? Mine continues to make noises for ages after I remove the key, always has done! It's a bit iffy, I know a motor flappy thing is misbehaving too.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,412
    Mine does not grunt LOL but does mmmmmm quietly about three times and stops.
    Mike
    Mar 2013
    Near Oxford
    352
    mine sounds like a planes turbone engine shutting down when I switch the car off, sounds cool as ****....
    I haven't noticed mine changing when I put my wipers on, and I don't get a screenwash smell in the cabin either.
    Jun 2009
    Co.Cork, Ireland
    20
    I noticed the fan speed picking up too when I use the washers. Thought it was a problem for a while and then figured it must be a feature.
    I think I might have a problem with my Climate Control though. I've noticed the lights flashing on it occasionally. Like it turns itself off for a second and them back on. Happens at random and only ever see it out of the corner of my eye. Not sure if the radio does the same.
  1. Climate Control Problem
    By adjturbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th December 2003, 21:38
  2. What's up with Audi climate control?
    By redaudi in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th December 2003, 14:43
  3. Audi A3 Climate Control
    By ramstein666 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2003, 20:18
  4. removing climate control module
    By DrX in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th September 2003, 08:30
  5. Retrofit LCD climate control
    By dandy in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2003, 11:42
