Chris NottJMB Retrofits
Results 1 to 12 of 12
Like Tree2Likes
  • 1 Post By quattrojames
  • 1 Post By Jules
Thread: A/C Part No needed
    Jun 2006
    UK
    148
    A/C Part No needed
    Now that the weather is finally starting to look up I am determined to get my A/C sorted. I plugged VCDS into it and it came up with this: High Pressure Sensor (G65)
    29-00 – Short to Ground
    I have looked into it and it's a fairly simple part to replace. Does anyone know what the part no is for this. I have a AVF 1.9TDI
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Google shows this: 8E0-959-126
    I haven't double checked it, but the G65 sensor is pretty common place.
    cnut likes this.
    Dec 2006
    barnsley
    1,020
    i would check exactly what you need to change the sensor
    some of them need to have the system emptied and cleaned before replacing the part
    i once saw a man try to change something like this on an mg rover and it took two of his fingers off
    be carefull working on the high pressure side of a/c units
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Mar 2004
    Leicester UK
    133
    I changed mine filled up no loss of coolant, if it is the one by the front bumper just need to get it scanned after wards. It is easier if you remove the front passenger light makes access easier
    cnut likes this.
    Jun 2006
    UK
    148
    Audi want nearly £60 for this :o Jesus I only thought they were around £30?!
    glenandem's Avatar
    Sep 2012
    manchester
    531
    Hi guys I've been looking at sorting my ac lately as its never worked but when I had front end off to do cambelt I noticed my pressure sensor was missing and there was no valve core in the centre of the hole where the sensor screws onto, does anyone know if this is normal or should I have a valve core like on a car tyre valve if u know what I mean lol!
    Mar 2004
    Leicester UK
    133
    Quote Originally Posted by glenandem View Post
    Mine had one think its called a schrader valve
    Apr 2012
    202
    Under the G65 sensor there should be as has been said a schrader valve in the pipe, this is so you can change the sensor without having to degas the AC system. But also you shouldn't expect this valve to be there someone may of removed it in the past and AC gas isn't something you want to come into contact with bare skin let alone your eyes, you will get frostbite and probably loose whatever it touches, due to it being pressured gas at around 6 bar plus it will cause irreparable damage.
    glenandem's Avatar
    Sep 2012
    manchester
    531
    hi mate, yes its missing and it should have one, thought it was funny as i used to do alot of ac servicing on cars at the garages i used to work at but we just plugged a machine in and let it go through the motions so to speak unless there was a leak or the system wasnt working after refilling!
    just not sure now whether to see if a shrader valve out of a tyre valve would fit or if its a special valve but i know i cant get one from audi as they dont list the part probably comes with the condensor!
    the other thing is i can fit a new g65 sensor and o ring and if i get probs in future i will have to get evacuate the refridgerant?
    Apr 2012
    202
    I think you can get the valves separately from Audi, I would try first. A normal tyre valve wouldn't be any good as I doubt the seals would be ok with aircon gas and oil.
    glenandem's Avatar
    Sep 2012
    manchester
    531
    yeah good thinking, never thought about the seal around the valve, i wonder though if audi dont do them separately from the condenser if i can just fit the new g65 sensor without it as all the shrader type valve does is to allow you to replace the g65 without having to degas the system so if i ever had any probs with the g65 i'd have to degas but better than having to buy a new condensor just becuase the shrader is missing!
    Apr 2012
    202
    True. You can fit it ok without the valve though I am sure you can get them separately as you can get the valve cores for the service points on there own.
  1. Part Number Needed - B6 Cabriolet
    By loafy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th January 2007, 21:53
  2. S3 Clutch VAG Part Number Needed
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th November 2006, 12:52
  3. Help Part Number Needed
    By simonwjones in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 3rd August 2006, 21:01
  4. A3 Servicing - what parts are needed?
    By dgannon69 in forum Detailing
    Last Post: 25th August 2005, 22:29
  5. does anyone have a part i need
    By a3kid in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2005, 17:11
