AH FabricationsEM Tuning
Results 1 to 11 of 11
Thread: Water meth??
    Andie0's Avatar
    Aug 2012
    487
    Water meth??
    Right i have taken my car to its limit before upgrading turbos or anything,mi was just wondering if anyone has attempted water meth in there 1.8t and what results they got from it! Want to squeeze as much power out of it on standard turbo to not risk blowing engine! Ive heard the lower intake temps and lower running temperature which come with installing water meth kit allow higher boost pressures and more bhp! Any info on this would be great thanks
    2004 audi a4 s line 1.8t bex 242bhp dynoed
    Mods: bsr optiflow kit, forge diverter valve, custom turbo back exhaust, custom 200 cell cat, DGR coilovers, forge tip, s3/tt 386cc injectors, boost gauge, revo stage 2, 12mm rear spacers, rear window extension spoiler
    To come: big brake setup... Getting there!!
    boats and hoesss, boats and hoesss
    carl-1968's Avatar
    May 2012
    Nottingham
    457
    I notice quite a reduction in inlet temps when mine is on, I'm yet to dyno it since installing the kit but it feels like it has more low down grunt than before.
    Andie0's Avatar
    Aug 2012
    487
    What kit did you fit in your car? Also what parts did you need, ive been told there is a spacer you an buy for between the inlet manifold and head that has a opening at top for the injector to screw into? Also did you set it up yourself?
    carl-1968's Avatar
    May 2012
    Nottingham
    457
    The kit is by cooling mist and my trusty mechanic installed it, the system is set up to start at 10psi and up and off at 8 psi, this avoids quenching. We removed part of the inlet pipework about 15cm upstream of the inlet manifold to keep the pipework from the sov as short as possible. I have a few photos somewhere so will try to upload them for you, we tapped into the washer bottle as it has a low level switch so I dont run the pump dry
    Andie0's Avatar
    Aug 2012
    487
    If you could upload them pics it would be great definetly want to go down this path soon
    carl-1968's Avatar
    May 2012
    Nottingham
    457
    This is the only photo i can find at the moment, I will take a couple of pics for you when I get home, The pump is mounted close to the washer bottle.
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    625
    Now you have it.
    What wld you reccommend?
    Water meth kit?
    Or bigger turbo?
    A4 avant b6.1.9 avf 6 speed. Bv43 turbo.uprated fmic. More bhp custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Rear parking sensors. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    Andie0's Avatar
    Aug 2012
    487
    I also would like to no the answer to that question! As am going to buy kit if it is decent so i can run advanced timing!!
    carl-1968's Avatar
    May 2012
    Nottingham
    457
    To be honest I already had my turbo upgraded, and until I dyno it i'm guessing as to how much difference there is, but I'd go with the bigger turbo even though it would probably be more money
    carl-1968's Avatar
    May 2012
    Nottingham
    457
    Andie0's Avatar
    Aug 2012
    487
    Looks sik want it... I think i will wait until i get my hybrid then go for this
  1. Replies: 28
    Last Post: 27th January 2013, 13:28
  2. Water Meth Injection
    By D2NY G in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th August 2012, 09:19
  3. water meth
    By flying oyster in forum Diesel forum
    Last Post: 8th March 2012, 19:07
  4. Water/Meth Injection
    By AGU-TURBO in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th June 2011, 15:43
  5. Water Meth injection
    By S3 Big Andy in forum Tuning
    Last Post: 22nd May 2009, 09:38
