    Feb 2013
    69
    oil change needed 1.9 tdi 130 b6
    has any 1 use castral edge or what should i use yearly change 10.000 miles
    Oct 2012
    434
    I will be using Millers pd oil personally, but you have a choice of either using longlife oil ( i won't be) or a good quality fully synthetic
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    Castrol Edge TURBO DIESEL for annual or less (ie fixed service intervals) oil changes which meets 505.01 spec, the spec quoted in the manual for the 1.9 tdi 130. Just put in my second batch and all fine in the 7 months I've been using it but to be honest, nothing to compare it with because it's all I've used.
    A4 Avant 1.9 TDi Sport GmbH
  1. Orange oil sensor light - 1.9 TDI 130
    By DALE_AVANT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th October 2012, 23:30
  2. auto gearbox oil change on 3.0 tdi quattro
    By .Jas. in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th June 2012, 14:11
  3. Oil Change Interval, 2.0 TDi??
    By RS_Cosworth in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th June 2010, 21:37
  4. Oil Change Procedure: 2.5 Tdi
    By Minxy in forum Diesel forum
    Last Post: 1st August 2005, 13:27
  5. A4 TDI 130 Oil Consumption
    By neiltdi in forum Diesel forum
    Last Post: 16th December 2003, 09:25
