AH FabricationsJMB Retrofits
Results 1 to 16 of 16
    4th set of a wheels in a year
    Jul 2012
    merthyr, south wales
    432
    Visit krisavant's Instagram Channel
    Wipers squeaking, banging. ARE they right ones?
    Since I've had car (1 year) the wipers has never run smooth across the windscreen.
    The ones that were on there when I bought the car were retrofit and were rubbish so replaced with Bosch retro fit but were still awfull, then tried Valeo and still same outcome.
    They all clear the rain fine but squeak, judder and sometimes bang.
    Anyone any ideas??
    I'm thinking I need to go back to the old style 'conventional' wipers and not 'retrofit'??
    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    The squeaking could be the spring inside the wiper arm, try lubricating it with some wd40 (obviously not getting any on the windscreen itself) mine was squeaking big time and it was well annoying (I have the B7 aero wipers as well) the knocking could be it hitting the A pillar when it's in motion, if it is that then the wiper arm will need to be removed and moved down towards the scuttle panel by a few teeth on the spline where the wiper arm bolts on to, this should stop the wiper arm just short of hitting the A pillar when in motion then.
    B6 A4 2.5 V6 TDi Quattro Sport
    Dolphin Grey I 210 BHP Remap I KW V1 Coilovers I 19"x9.5" all round BBS LM reps I RS4 Anti Roll Bar Kit I S4 Front and Rear Bumpers I Votex side skirts I S4 Aluminium Mirrors I S4 Rear Spoiler I S4 Style Tailpipes I USDM S4 licence plate blank I 6000k HID's I 18 SMD DRL's I Cupra R Splitter I Full RS4 black leather with white stitch optional bucket seat interior I RS4 black headlining I TT S Line FBMFSW I Aluminium Trim I Reverse camera I Full DIS I Cruise Control
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    Like Az says, my aero wipers were catching the A pillar on the drivers side. It was rubbing the plastic trim on the pillar and appeared to have coated the windscreen with a plastic film. Adjusted like Az describes and a couple of goes with some glass polish sorted it.
    A4 Avant 1.9 TDi Sport GmbH
    Jul 2012
    432
    The banging is the wiper bouncing on the windscreen. Sorry should have made that more clear.
    The wipers sit perfect and don't hit the pillar.
    I've got rain x on there also.
    The wipers just won't glide, even in heavy rain.
    Will the b7 aero wipers be a direct fit or do i need the arms?
    Apr 2012
    lincs
    210
    wipers can bang when the pivot on the arm goes (wears at the blade end) they effectively flick from one direction to t'other at the end of travel and you get the 'bang' noise - the only cure is new arms if that's the case. The mech wears too under the scuttle panel.
    b7 arms a straight swap (if you can get the old ones off ok) the part numbers are in the sticky and i got mine from a stealer for about £67 for arms and £21 for the two aero-blades
    A4 2.5 tdi Q sport '02 AKE, "minor modder", 18x8's S4 Avus , Zender Monza's 18x8.5's, aero wipes, interior trim, dis and cruise, real s4 mirror caps, rns-e led, dble din, VCDS owner-learner - GMBH next
    Dec 2011
    Wales
    106
    You will need to by the arms as well.
    Jul 2012
    432
    The passenger side wiper on the arm is a bit wobbly, but thought that was the norm.
    New b7 arms it is then!
    Thanks guys!!
    Means we're on the wiper subject...
    Is there another style 'rear' wiper out there to replace the chunky one for the back screen??
    E.g golf mk6 rear wiper etc... Or something as slim line as those?
    Sep 2012
    Swindon
    371
    Quote Originally Posted by krisavant View Post
    I believe the "slimmest" option is to remove and blank
    Jul 2012
    432
    Quote Originally Posted by Audi Doodah View Post
    Tempted, very tempted!
    If there is no slim line type I will.
    Gonna look into the new Avants & passats first to see what rear wipers they have, taking measurements and spray pattern first into consideration.
    Apr 2012
    lincs
    210
    yes you can get an aero rear - i've put one on mine - there's a picture on my wheel thread.
    cost about 30 for arm and blade (ebay - mine came from germany or poland but is audi part.
    edit - this one - Original Audi Aero Twin Aerotwin Rear Wiper Blade Set A4 S4 8E B6 B7 +Avant | eBay
    (was £29 plus post when i bought)
    Jul 2012
    432
    Thanks! Will be purchasing that!! 😉
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Plenty of rear wiper geekery here:
    Aero rear wiper options.
    Jul 2012
    432
    Doh!!!
    I fitted a polo rear wiper to my fabia vrs, could have swapped them over before I sold car!!!
    Jul 2012
    432
    Squeaking, juddering, banging wipers sorted!!
    Pinched the end of the wiper arm with pliers so it grips the wiper blade better and gives it a tight snug fit.
    Now wiper doesn't wobble around/judder going across windscreen.
    Temperamental? We'll see.
    Don't think rain x is helping with the glide either...
    Aug 2011
    196
    Lovely - but, B7 arms and aero blades are SOOOOOOOO much better!
    Jul 2012
    432
    They're still on my list. Lol
  1. Would these wheels look right on my a3 or are they to small?
    By braque10 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st May 2011, 02:17
  2. 235/35/19 are they right for 8.5j alloys?
    By allyp in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th February 2011, 15:14
  3. Anyone got one of these bonnet bra's? And are they any good?
    By DJM1982 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd June 2010, 08:44
  4. Clutch Is It Covered By Warranty? Are they trying to have one over me?
    By Ash B in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th July 2009, 14:07
  5. Right - Are they talking pish ??
    By R14AYN in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 21st November 2007, 20:25
