AH FabricationsChris Nott
Results 1 to 16 of 16
    SMc
    SMc's Avatar
    Jul 2004
    Glasgow
    135
    New turbo fitted but losing power, feels restricted like air mass flow meter fault?
    My turbo was on the way out with leaky seals so just had a recon turbo fitted. Car idles and revs ok when in neutral, but on the road it has a big flat spot between around 1500rpm and 3000rpm. If you try to accelerate from low revs it just doesnt go anywhere! once it gets past 3000revs the turbo seems to be spooling ok.
    It seems to be showing the characteristics of an air mass flow meter fault but the car was running perfectly before we changed the turbo.
    Just for the record, it was fitted by a good mechanic who has done many turbos before...we are both pretty sure everything is back where it was so struggling to find the fault. Any ideas?
    Oh, its a 2002 A4 Avant 1.9TDi Sport 130bhp.....
    Thanks in advance for the help....
    On my 3rd Audi.....my latest PROJECT...... a 2002 A4 1.9TDi Avant Sport.... wrapped matt white with 19" VMR matt black wheels.
    Oct 2008
    Glasgow
    431
    Boost Leak or limp mode. Do you have access to vag com so you can check fault codes?
    beachbuggy's Avatar
    Surrey
    1,744
    Quote Originally Posted by SMc View Post
    wastegate issue, either not plumbed in properly or as its a recon unit not setup up correctly
    Jul 2007
    London
    3,235
    The PD 130 engine uses a VNT turbo, there's no wastegate there. I would pay attention to the vacuum hoses as it's easy to knock them off and if there's a vacuum leak then the turbo wont boost properly. As hector mentioned, i would scan the engine for fault codes then take it from there...
    FOR SALE:
    SMc
    SMc's Avatar
    Jul 2004
    Glasgow
    135
    Thanks guys....still not solved this. Mechanic has checked and pretty damn sure everything is on the way it should. The EGR valve was clogged so we changed that but it still drives the same.
    There are no fault codes to indicate exactly what's going on, he's got the diagnostic equipment.
    I should say, it's erratic the way it performs. If you accelerate fairly quickly from a standing start it seems to be ok in 1st and 2nd gear....and turbo spooling as it should....then when you are continue in 3rd it just kind of dies and wont accelerate more.
    We're going to try the air mass flow meter next but if its not that, I'm guessing beachbuggy may be right and its the recon turbo thats the problem
    beachbuggy's Avatar
    Surrey
    1,744
    Quote Originally Posted by adamss24 View Post
    I meant vnt, I did know, just typed the wrong thing:-) too used to 1.8ts!
    Jul 2012
    Derbyshire
    306
    Not an audi but my impreza used to do this and it was because it was over boosting and hitting it's safety cut off not sure if its anything like on these cars but have you tried resetting the ecu and then building the boost up gradual in each gear allowing the ecu to learn the parameters,like I say not sure it's the Same on these cars but just a thought that may help
    SMc
    SMc's Avatar
    Jul 2004
    Glasgow
    135
    Ok...an update!
    We have now changed the air mass flow meter today and on the test drive, it immediately felt better. I felt there was still a slight bit of lag compared to the old turbo but at least it was consistent and drove in a 'normal' fashion. However, after a few miles of stop-start and open road driving I went on to the motorway and accelerated up into 5th and the car ran out of power....foot to the floor in 5th and it would not accelerate past 80mph. Came off the motorway and the car was back to the way it was....sluggish, incosistent, totally lacking power etc....
    So....we are back to square one. What's confusing is how the car ran apparently ok for the first 15miles or so after the air mass flow meter was replaced...but then suddenly slipped back into running like a plug again?
    This is driving us nuts!! Please can anyone help?
    SMc
    SMc's Avatar
    Jul 2004
    Glasgow
    135
    Bump....someone must have an idea? appreciate any help or suggestions....
    I have noticed a pattern......when you first pull away it drives close to normal...accelerates and boosts in every gear....but after the first minute or so, usually when hitting around 2500rpm in 3rd gear....the car nosedives and slips into what is like a limp mode....acceleration is then almost non-existent. But, stop the car and restart it...we have boost and 'normal' driving again....until 3rd gear and 2500rpm again....then into a limp mode again.
    Any ideas? Can this be a problem with the actual turbo itself? The car was running fine before we changed the turbo (albeit the turbo seals had gone and there was oil in the system).
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    636
    Have you thought about returning the turbo and getting another unit. Have heard of recon unit messing about
    SMc
    SMc's Avatar
    Jul 2004
    Glasgow
    135
    No yet mate, need to eliminate everything else first as it will be a bit of a job!
    Another factor...my mate followed me and said under heavy acceleration...there is heavy black smoke coming out the exhaust.
    Jan 2013
    Bath
    69
    This sounds very similar to what I'm experiencing at the moment. Only started a few days ago and have done absolutely nothing to the car recently.
    Going to start investigating this week and will post back if I find anything.
    SMc
    SMc's Avatar
    Jul 2004
    Glasgow
    135
    Likewise mate....I'll keep you posted on this thread how it goes for me and maybe it can help you
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    Have you done some boost logs? Engine block 11 in vcds shows required and actual boost. Issues with the map or n75 would log a fault code though, I think.
    Otherwise, I think you have to admit the turbo is a fault. It's the only major part you've changed. Happens quite a lot in my job fixing military aircraft, believe it or not. Unserviceable on fit, we call it.
    A4 Avant 1.9 TDi Sport GmbH
    North East
    607
    I have had almost exactly the same issues as yourself. The diagnosis from my Indy is that the turbo vanes are sticking. I am fitting a new turbo tomorrow and would suggest you take your turbo back for a refund/exchange. Good Luck .
    BRILLO's Avatar
    Sep 2011
    Juniper Green, Edinburgh, United Kingdom, United Kingdom
    137
    did you ever get to the bottom of this
  1. Cost of a new turbo fitted?
    By martyboy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th September 2009, 16:23
  2. New turbo fitted but still the noise remains.
    By Turbo Lag FTW in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th August 2009, 15:19
  3. New head unit, but no power.
    By parmarano in forum In-Car Entertainment
    Last Post: 1st April 2008, 14:54
  4. Rollbars fitted - but something doesnt feel right
    By nershen in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2007, 14:53
  5. New Kitchen fitted but one problem..
    By Rev-head in forum General Chat
    Last Post: 25th April 2006, 09:26
