Sky InsuranceJMB Retrofits
Results 1 to 7 of 7
    Sep 2009
    95
    A4 B6 Avant Both Front Doors Knock On The U Catch ( Can They Be Adjusted )
    Hi,
    Could some advise me if they can be adjusted so they lift up a few mm or I need to buy a new top and lower hinges?
    Sam
    Sep 2009
    95
    anybody?
    Nov 2012
    194
    Dont know if adjusting just helps for a moment.. Could be wear inside the hinges. But there is an adjustment screw on the top hinge I Think..
    But how it works I dont know..
    My drivers door needs just a little harder push than the other three doors..
    So maybe my door also could need an adjustment..
    Nov 2012
    194
    Did you figure it out??
    Dec 2006
    barnsley
    1,016
    look at the catch carefully .... it should have a little cross design on it which allows it to be moved in every direction a small amount
    undo the two allen bolts then move the catch a couple of mm and re-tighten then try the door
    should help things a little
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    as above
    Nov 2012
    194
    If the catch is moved and the hinges are worn then won't the door just sit wrong when closed ??
  1. Avant front door speaker pods
    By wellhouse0 in forum In-Car Entertainment
    Last Post: 22nd July 2008, 17:24
  2. Knocking from the front during gentle braking ???
    By noodle in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2008, 22:29
  3. S3 Front Suspension Knock
    By gdwood in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th July 2004, 12:25
  4. A3 front door speakers
    By AndyMac in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2004, 10:56
  5. S3 Front Door Speakers
    By mramage in forum In-Car Entertainment
    Last Post: 5th April 2003, 21:05
