Results 1 to 10 of 10
    Sep 2009
    95
    B6 tdi strange noise from air box on idle thumping sound....???
    Hi,
    wonder if anybody can help me 1.9tdi awx
    Started the car this morning and a loud thumping noise from the engine bay after a closer look I removed the air ducting cowling from the top of the air and there was the noise but louder its something I haven't noticed ever before...
    run the car about about 15-20 miles and parked up done my shopping return and started the car and the noise wasn't there removed the cowling on the air box again the noise was there once removed but not as loud as before just don't have a clue what it was????
    has this happened to anybody before
    thanks
    sam
    Oct 2009
    Hull
    1,440
    thumping in the airbox is a sign of a dropped valve!
    although it doesnt usually get quieter it would be that same all the time or louder when reved
    Sep 2009
    95
    Well when I revved it when the noise was there I couldn't here the thumping at all only on idle...? How could you find out a valve has dropped? Would it be expensive to fix ...? Started the engine a few times just can't get the noise to come back.? Weird it was on of them when u hear something unusual and not heard before ... Hope it's not to drastic
    thanks
    Jul 2007
    London
    3,234
    Worn camshaft and lifters, take the rocker cover and look at the cam lobes and compare them for wear...
    FOR SALE:
    Oct 2009
    Hull
    1,440
    if its not their all the time or when you rev then it wont be a valve as you would know
    check the cam and lifters as mentioned above
    Sep 2009
    95
    I wouldn't no what I'm looking for tbh but would it cost a lot to fix??
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    636
    Would worn camshafts be common on the awx engines?
    Sep 2009
    95
    Am I ok to run the car and how much would I be looking at to fix if it the cam lifters?? Would I be doing damage if run?
    Sep 2009
    95
    anybody???
    would this damage the engine running the car? Cost to fix a ruf price
    Ta
    Jun 2006
    UK
    143
    Before worrying too much could you possible post a sound of video clip up of the noise? This is what bad cams generally sound like when they are worn: PD TDI with BAD camshaft rapping noise NOT exhaust leak - YouTube
  1. Clicking noise from glove box area ( Audi a4 1.9 tdi 52 plate )
    By dean2013 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd March 2013, 17:53
  2. Strange noise from air con
    By s4mark in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd November 2011, 23:09
  3. Strange noise :-/ from audi a3 tdi 140
    By mA3tty Quattro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th October 2011, 13:31
  4. strange noise from rear of car @ 4500rpm +
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2007, 17:50
  5. clicking noise from air vent???
    By xdam in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2004, 00:53
