Chris NottBadger5
Results 1 to 10 of 10
    Apr 2013
    Farnham, Surrey
    quattro estate wheels
    hi , ive just purchased a quattro sports estate, v6 3.0 its a 2002 car, i want to change the wheels, but am unsure what et and pcd they are, i thought 112 x 45 but after hunting high and low for wheels im even more confused, i reallt fancy a set of rs4 rep wheels on it.. grahpite grey perhaps.. but dont want to make the mistake of buying the wrong ones ! which is more important the et or the pcd ?
    thanks in advance
    Mar 2013
    83
    Im pretty sure the replica's would be mutli-fit and fit regardless of the cars offset, not sure what offset the car is however sorry, somebody will probably be along shortly to offer a hand.
    Apr 2013
    Farnham, Surrey
    thanks, really fancy these on flea bay 18 INCH AUDI RS 4 ALLOY WHEELS | eBay
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,806
    I'd say the pcd was most important, and it needs to be 5x112 with a 57.1 centre bore as far as I remember. Spacers can be easily fitted if required. I seem to think most oem wheels are around 40-45 as a guide.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by martyn s View Post
    They'll fit perfectly. You want 5x112 (that's the PCD, you can get adapters, but why bother when 5x112 is such a common fitment). Standard ET is typically 43-45, but most people aim for ET30-35 depending on wheels width, desired look etc, and oem Audi 18's on our cars are 8J wide. Spot on.
    Apr 2013
    Farnham, Surrey
    Thanks, I will be purchasing wheels tommorrow
    what tyres can I fit ? i dont want to shake my teeth out, nothing too low profile...
    Greeny233's Avatar
    Mar 2011
    Llangollen
    698
    Follow Greeny233 On Twitter Add Greeny233 on Facebook Add Greeny233 on Google+ Visit Greeny233's Youtube Channel Visit Greeny233's Instagram Channel
    You'll need to fit 225/40-18 tyres which will keep the rolling circumference correct. It shouldn't give a harsh ride, I run 235/35-19's and the ride is still ok.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    235/40/18 are also good as you get a bit more rubber. Cost slightly more though
    *WANTED* AUDI CD PLAYER
    crazy88's Avatar
    West Yorkshire
    4,806
    235/40/18's are the correct size to give you the right circumference. 225 will be slightly lower circumference, but as long as they're all the same it should be fine. And as said, 225's are slightly cheaper.
    I run 235/40/18 on mine.
    Greeny233's Avatar
    Mar 2011
    Llangollen
    698
    Quote Originally Posted by crazy88 View Post
    Yep my bad, 235/40-18's are closer to the rolling circumference of the original tyre size.
  1. '53 A6 Quattro Sport Wheels
    By 936ADL in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 27th February 2008, 22:28
  2. 1996 A6 2.5TDi Quattro Estate Glow Plug Problem
    By mmarks in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 20th May 2007, 20:13
  3. Quattro 4 wheel drive alignment
    By imported_flava in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th March 2005, 17:31
  4. 1996 A6 2.5 Tdi Quattro Estate Glow plug problem
    By mmarks in forum Diesel forum
    Last Post: 4th December 2003, 19:54
