JMB RetrofitsBadger5
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    Stanley, North East, UK
    292
    should your instrument cluster warnings show in vcds?
    My brake wear indicator light is on in the top half on my display but cant find out why as my pads are like new, it has flashed on now and again before but now its on perminantly and its annoying. Vcds isnt showing anything unless im looking in the wrong places?
    blacksmoke remap, 18" alloys, coilovers, heko wind deflectors, c/coded door blades, DIS, Cruise, votex front grille
    TO DO: fit my votex front valance (in the shed), c/code the rest of the lowers, sport interior
    Dec 2006
    barnsley
    1,020
    do a full auto scan with vcds
    this should pull any fault code up that the car has
    it will be under section 3 abs and brakes not section 17 instruments
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    Tried both of them but didnt do auto scan al do that tomorrow, cheers
    Mar 2013
    83
    The instrument page of VCDS will show you a brake error,
    You will need to check the ABS ECU if i remember rightly.
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    I checked mate and didnt show anything just said no errors found or something along those lines. I will try a full scan and see what it comes back with. If it show no faults like last time i will take a photo of the screen and take a photo of my dash. Its very odd
    benjie's Avatar
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    645
    Low brake pads aren't an error, so don't think it will show. When I had the common "red brake light on startup/low battery" issue, it never left any fault codes. Neither does low washer fluid.
    As a side note, you prob have the yellow light because the wiring harness on the brake pads has either come out or come off.
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
  1. Fitting a B7 instrument cluster into my B6, VCDS needed?
    By Az in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd March 2013, 18:42
  2. Audi A6 Instrument cluster testing with VCDS
    By Jetcat in forum VCDS (formerly VAG-COM) forum
    Last Post: 20th February 2011, 21:27
  3. Do you want your instrument cluster with bad pixels fixed?
    By diesel-a4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd January 2008, 20:42
  4. A4 instrument cluster problems........ common?
    By dachtor in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2003, 01:34
  5. Sony Head units and the instrument cluster display
    By Ram in forum In-Car Entertainment
    Last Post: 14th April 2003, 23:30
