EM TuningSky Insurance
    Aug 2010
    Kent
    15
    Misfire problem on 2.4 v6.
    Just had the clutch and flywheel replaced and a full service, after the service the car immediately developed a misfire on cylinder 4 (shows on the error codes) before all the work was done there was a very light hesitation in acceleration but now it misfires on idle and under load.
    does anyone have any suggestions?
    many thanks
    Scotty
    Mar 2009
    471
    Maybe coil pack/packs, have you had them replaced under the recall and have you scanned the car for fault codes?
    B6 S4 4.2L V8 Cabriolet Black Manual Quad Milltek Non Res
    Aug 2010
    Kent
    15
    I think i will have to speak to audi, no paperwork from the previous owner to show that if they have been replaced under the recall or not. yes i have the fault codes, shows two, 16683 and 16688 to show that its number four cylinder that is misfiring. is there a process i can use to check like swapping ht leads over?
    RyanJonS4's Avatar
    Drive It Like You Stole It
    Mar 2009
    Oldham
    287
    could swap 2 coils, clear fault codes and try again to see if misfire mov es to a different cylinder?
    Milltek non-resonated cat-back - 15mm MTM spacers - Toyo T1R's all round - RS4 Pedals+foot rest - Blackout model front grilles - Custom black front badge - de-badged boot - R8 oil cap - silver indicator bulbs - Dodo Juice supernatural wax - ECS tuning Porsche cayenne brake kit ready to fit or sell?...
    Mar 2009
    471
    +1 .
    If you take it in to Audi they will have a look at the coil packs for you to see if they have been replaced.
  1. Hesitation/Misfire problem
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2010, 18:56
  2. A3 2.0 170 Tdi Quattro 2006, misfire problems
    By DSan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th January 2010, 13:43
  3. 3.0 misfire problem - running out of ideas...
    By amiller001 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th January 2008, 16:15
  4. 1998 audi a3 1.8t, misfiring problem
    By a3phil in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th November 2007, 23:09
  5. S4 Misfire problem.
    By tonyt102 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th March 2007, 21:17
