    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    Thermostat and coolant temp sensor (G62) location on 2.0 petrol
    Can anyone point me in the direction of both parts mentioned in the heading for a 2.0 NA B6 engine please? (can't remember engine code)
    Thanks in advance,
    Az
    B6 A4 2.5 V6 TDi Quattro Sport
    Dolphin Grey I 210 BHP Remap I KW V1 Coilovers I 19"x9.5" all round BBS LM reps I RS4 Anti Roll Bar Kit I S4 Front and Rear Bumpers I Votex side skirts I S4 Aluminium Mirrors I S4 Rear Spoiler I S4 Style Tailpipes I USDM S4 licence plate blank I 6000k HID's I 18 SMD DRL's I Cupra R Splitter I Full RS4 black leather with white stitch optional bucket seat interior I RS4 black headlining I TT S Line FBMFSW I Aluminium Trim I Reverse camera I Full DIS I Cruise Control
    Aug 2011
    196
    Not sure if this helps much, but my Haynes says "On petrol engines, the thermostat is fitted to a distribution housing on the left hand side of the cylinder block, behind the coolant pump position" . Depending on the engine code, there seems to be varying degree of dismantling to get to it.
    The coolant temp sensor info is "On all models, an engine coolant temp sensor is located at the rear of the cylinder head, whilst on some engines, a second sensor is fitted to the radiator outlet pipe".
    Mike.
    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    That's great, thanks very much for the info mate, I'll have a look out for those positions then.
    cookiesvw's Avatar
    Sep 2012
    88
    I know this doesn't help but on my 1.8t I changed the temp sensor and it was one of the most fiddle and frustrating jobs I've had to do. I lowered my gfs tt at weekend and that felt easier.
    Mar 2013
    Near Oxford
    405
    Quote Originally Posted by cookiesvw View Post
    I'm doing mine on Saturday, did you take the y boost pipe out? I think this would make it easier
    CEC
    Exhausted
    Dec 2010
    Clitheroe, Lancashire
    Hi Guy's,
    I have the same problem only mine is the 3.0 v6,Should I be looking in the same place ???
  1. Coolant temp sensor location on 2.0 tdi BLB engine code
    By polo10v in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th March 2013, 20:43
  2. Coolant temp sensor change and EPC problem
    By BuuBBa in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th March 2012, 19:48
  3. coolant temp sensor location? (APS) 2.4 v6
    By melteddrummerr in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th August 2011, 20:57
  4. 16502 - Engine Coolant Temp. Sensor (G62): Signal too High
    By dellboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2011, 14:59
  5. Air Mass Meter and Coolant Temp. Sensor
    By nu boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th April 2008, 20:29
