JMB RetrofitsSky Insurance
Results 1 to 8 of 8
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Question Anyone got a spare Avant bootlid solenoid/actuator.....
    .....knocking around. I think mine needs replacing. Works 9 times out of 10 then just gets stuck
    *WANTED* AUDI CD PLAYER
    Smillie13's Avatar
    Sep 2012
    West Lothian
    933
    Follow Smillie13 On Twitter
    Anyboy got 2 as mines is away as well
    Susan
    Here for a good time, not a long time
    x Susan x
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    368
    How funny make that 3 mine messed about for the first time this morning I dissected it but couldn't get the little motor out to clean the brushes as its fixed (soldered) in situe on a plus side after looking into it there very cheap to buy new any how.
    I think this is the part number as used by others carrying out the repair 8E5962115B
    8K xenon upgrade-LED side lights-LED number plate bulbs-Apex springs-B5 perches-Votex front & rear valance, side skirts, roof spoiler-LED Fog re-wired as DRL's-DRL's wired as see you home lights-Rear lights tinted-centre box removed-4" tail pipes-LCR front splitter-Spacers Front18mm Rear19mm-S4 door blades-RS4 style grill-B7 aero wipers-K sport 8 pot caliper 356mm 2 piece discs - 19x8.5 Cades Apollo wheels-De-chromed roof bars and window surrounds-Engine bay tart up-Window tints-RS4 rear ARB
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Mine has Part # ZSB 4B9 962 115 B printed on it???
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    368
    I'll be ordering one in the morning,
    I'll just give them my chassis number and get them to supply off that and I'll post back the part number they give me, part numbers are some times superseded so there's no telling what it currently is so I'll let you know what they give me tomorrow.
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    368
    Well after calling TPS Monday morning I was expecting it to cost around £12 after seeing what others had previously paid but even at trade cost TPS wanted £33 plus vat so £39 all in.
    So thought I'd give something a try before parting with my cash, I had at home a few door lock solenoids from a previous project and set to work at fitting one in replacement to the stock solenoid and it works perfectly.
    The solenoid I originally picked up from Maplins for £7.99 so nearly a 5th of the cost of a new OEM one and all I had to do is drill 2 4mm holes to mount the solenoid and connect up the 2 wires took 20mins to fit, job done.
    Solenoid I used (ignore the box in my pics when I packed them all away last time i put it back in the wrong box it's the 2 wire not 5) :
    2 Wire Door Lock Motor : Vehicle Security : Maplin Electronics
    couple of pics:
    old set up:
    new one fitted:
    Mar 2013
    83
    In your last picture it looks like the fitting of the rod to the solenoid is a little insecure, is it just the picture? I think id be tempted to add locktite on those screws to prevent vibration, or could you not simply hook the rod into the hope ontop of the new solenoid?
    Looks a clever mod and saves the pennies, and easy/cheap to replace when the cheap one breaks too.
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    368
    Quote Originally Posted by Legacy87 View Post
    Was going to hook it through the solenoid loop but the rod needed to be twisted 90 degrees but had no decent tools at home, I gave it a try with pliers and it was just deforming the rod so stuck with the clamp it comes with and its very well secured used these solenoids many times and never had a problem with them coming loose.
  1. Anyone got a spare repair wire?
    By redbutcher in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd December 2008, 09:39
  2. Phatnoise Cable - Where From?? Anyone Got One Spare??
    By NS1 in forum In-Car Entertainment
    Last Post: 14th May 2008, 21:53
  3. Anyone got a spare 17 AVUS S3 wheel laying around ?
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2007, 18:11
  4. anyone got a spare front strut for a B5 A4?
    By jcb in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th November 2007, 07:49
  5. Anyone got a spare
    By JayB5UK in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th November 2006, 17:11
