    Oct 2012
    Wigan
    178
    REAR WASHER PIPE ON MOTOR
    After detailing the car today remembered the rear wiper wash jet never worked, After stripping the panels of I took the pipe of with the little 90 degree angle plastic bit on it, and water was coming out, but it seem it is a very very loose fit back onto the motor, resulting in it not having a good seal,
    Has anyone had this problem and can you buy either a universal clip of the original ?
    Oct 2012
    425
    oddly enough no thats how they are, i think it seals but only just, the problem lies inside the motor,either the jet is blocked or the pipe that runs inside the spindle is broken and water is leaking that way. only real solution is a new one
    Oct 2012
    Wigan
    178
    i put it on and it sprayed every were i will try to unblock the jets tomorrow
    CEC
    Exhausted
    Dec 2010
    Clitheroe, Lancashire
    Hi, I had the same problem with mine and spent ages cleaning the jet to then find out I could get a new one from TPS for loose change!!! not worth spending time cleaning just get a new one mate.
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    547
    Add GeoffDunk on Facebook
    Also, it may be a problem with the motor tube. If its anything like Passats then the pipe connects to a tube that runs through the motor shaft and that gets blocked causing water to piss out of the boot after a heavy attempt at use.
    Audi S4 quattro in Dolphin Grey Metallic, Silver leather, carbon inlays, RNS-E, 6 speed manual, electrically adjustable & heated seats, xenon headlights with power wash, cruise control, storage pack, 18" OEM RS4 wheels, RS4 ARB, LED lighting upgrade, FASH plus every bill since new.
  1. A3 Rear Washer Pipe?
    By reptor245 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th December 2013, 22:24
  2. Rear Washer Pipes
    By Legend7 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd February 2012, 12:20
  3. Rear washer pipe
    By G60DAN in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th January 2011, 15:49
  4. split rear washer pipe
    By scott b in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th January 2011, 19:18
  5. Rear washer pipe split in engine bay
    By koonl in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th April 2004, 20:25
