Monster MotorsportVolks Autos
Results 1 to 9 of 9
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    551
    Add GeoffDunk on Facebook
    Question Dropped drivers door, anyone else seen this?
    Hi all,
    I have resently noticed a significant drop in my drivers door, very other door is fine.
    When the door is closed the latch lifts the door almost into its correct position, but when opened it drops by at least 5mm which is realy noticable when the door is on the 1st step of the latch.
    What else is noticable is that the inner door cards are miss aligned too which is very anoying becasue as we all know the b6/7 door cards rap round from the dash and join the door in a good looking way.
    I can't see any adjustment on the hinge, can they be adjusted?
    Regards,
    Geoff
    p.s. I could have the upper door fram raised to compensate but I would rather not have done this if I could help it.
    pink.teg's Avatar
    Jan 2012
    Cardiff
    170
    Hi m8
    within the few days my front wheels have started to sweek when on turn and my
    drivers door also has dropped around 2 mm
    The same thing when closing the lach brings the door up to its proper place ...
    Quattro Jam B12 suspension kit ,Custom Droplinks F/B , HID 6000, 18" RS4 Alloys, summer AMG's .
    RS6 for Show's .Cat gone for walkees, sports six padded clutch DMF
    Remapped 173BHP///278lbft, RS4 F/R ARB's , happy with that ........
    Jun 2012
    Teesside
    448
    Mine has dropped also which is beginning to annoy me as its rubbing the edge of my wing, surely there must be a way of adjusting it.
    Mods done: interior: Light to dark conversion, To Do: Carbon trim, carpet to be replaced, rear window retrofit. Exterior: Resprayed in Skoda's Rallye Green, 18" RS4 reps fitted, xenons, LED sidelights/NumberPlate lights, B Pillars wrapped in carbon. To Do: Lowering 35mm all round, tints, Tuning: Yet to do exhaust/remap/ egr delete etc..
    munchkincoupe's Avatar
    Aug 2010
    971
    do you regularly park on a slope? had your door open for a long period?
    That's how mine dropped on my 3 door A3
    Not a very precise way to adjust your door and I will warn you that if you aren't careful it could damage your hinge but this is how I adjusted it on the A3
    Long piece of wood under the widest section of the door metal (not the edge of the outer skin) under the rear half of the door. Trolley jack underneath the wood and raise up very slowly and gently - lower again then recheck the door - repeat until level
    This is at your own risk and is only if your hinge isn't the fault
    Jun 2012
    Teesside
    448
    My cars always on the drive which isn't sloped but ive only owned the car for 11 months so cant really comment for previous owners, may give that a go I may also compensate for it a little when I fit a new wing,
    Jul 2012
    Fife
    17
    My drivers door doesnt sit right either, however, it looks level but it looks like the whole door is a few mm further toward the wing that it should be, leaving a bigger gap between front and rear doors if that makes sense?
    Is this something that can be adjusted like the level of the door can be? Its bugging me now because it doesnt sound right when you close the door or when youre on a bump road.
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    Must be a member on here that works at a body shop
    A4 1.9TDI Sport - 130 (B6) / Mods: None yet, just getting the basic right first
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    Quote Originally Posted by scottshere View Post
    I'm a panel beater by trade
    i haven't had a close look at the hinge on mine as my door has dropped too but I think there is one big bolt going into the A post through the hinge, loosen this a little and lift the furthest part of the door a bit then tighten.
    you may need a friend and might need to slacken the top bolt too.
    or it could be your striker plate at fault. Could adjust that too.
    il look tomorrow and try and get more info for you
    03 Mig blue 1.9tdi 130 saloon:- GMBH front, dark tints all round, fk coilovers,
    BMW TIGERCLAWS 19" 9j front + 10j rear, debadged rear. HIDs 6k, egr delete
    cominig soon:- votex rear,front end respray, parrot kit, remap, full paint correction
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    Quote Originally Posted by mattyb6 View Post
    Cheers....
  1. Anyone else seen this on Top Gear
    By dpeilow in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2006, 00:09
  2. Anyone else seen this?
    By Markey in forum General Chat
    Last Post: 23rd March 2005, 16:50
  3. Servicing the A3 myself ? anyone else do this...
    By faisal in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th February 2005, 11:08
  4. To my fellow S8/A8 drivers (and anyone else...)
    By SvenS8 in forum A8/S8 forum
    Last Post: 21st December 2003, 19:25
  5. Does anyone else have this problem?
    By audi_girl in forum General Chat
    Last Post: 22nd October 2003, 00:15
