AH FabricationsEM Tuning
Thread: Creaking car
    deburgh999's Avatar
    Feb 2011
    64
    Creaking car
    I had my a4 sline lowered last week, the garage had to replace all 4 upper control arms as mine were damaged when removing them, since then the passenger side I have had a creaking on low speed and when breaking plus when turning steering, actually quite loud. Garage told me it was probably lower arms so I changed them at weekend and noise still there. Garage have agreed to remove the arms they fitted and fit genuine oem arms but if noise still there I have to pay for it all, question to you all is has anyone come across this before and could it be something completely different.? There was no noise before they changed arms first time round and they did fit the cheaper option from local auto factors.
    Feb 2011
    Ireland
    41
    This is a common problem and is definitely a control arm joint. Finding the offending one can be difficult. I changed an upper arm recently and took off the rubber boot to examine the joint. There was little or no grease in the joint hence the creaking. I have heard it said that you can slip the narrow tube of a spray grease can past the rubber and spray grease into the joint which may help? Never tried this though.
    deburgh999's Avatar
    Feb 2011
    64
    Creaking car
    Yeah I have found a lot on Internet about new arms being badly greeced up, I'll let the garage fit new oem arms and go from there, just hope it is otherwise I think this could turn expensive.
    simon.m's Avatar
    Oct 2009
    2,746
    i had a creaking sound on mine at low speeds for over a year could not pin point it at all was told it was one of my control arms but when i had the car mot i was told i had the smallest bit of play in my stearing rack easy fix just got a new inner tie track rod like the one in the link problem solved and i was told by a few ppl it was every thing but this yet my creak stoped the day i canged it
    Audi A4 Delphi Left or Right Inner Tie Track Rod Axle Joint Genuine Steering | eBay
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    253
    Audi suspension... creaks and groans can drive you to distraction. OEM replacement parts is a step in the right direction. You could also start with some relatively fixes, such as replacing ARB rubber bushes and ARB links. Simply replacing upper arms just transfers load to worn components elsewhere, so it could very well be a worn ballpoint in the lower arms as suggested.
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    deburgh999's Avatar
    Feb 2011
    64
    Problem sorted now, company removed arms and replaced with audi ones and creaking has gone completely also they found my sub frame, audi had replaced the bush in 2012 but put the washer on wrong so this could have caused some noise as it was rubbing between bushe and chassis of car. Lesson learnt never allow companies to fit non oem parts to car.
    I'm interested in doing my arb bushes but as a upgrade, what is recommended to fit?
  1. someones twatted my car
    By danksy in forum General Chat
    Last Post: 18th January 2003, 22:29
  2. What kind of company car do you get?
    By worfke in forum General Chat
    Last Post: 13th January 2003, 08:58
  3. where can you post cars for sale?
    By Stormcatcher in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2003, 18:30
  4. My first car;
    By richyboy in forum General Chat
    Last Post: 10th January 2003, 15:52
  5. Wedding Car
    By Drystone in forum General Chat
    Last Post: 7th January 2003, 08:48
