Volks AutosAH Fabrications
Results 1 to 10 of 10
    Apr 2013
    help! Rough clutch pedal vibration...
    Just bought an a4 B6 I believe, 2004 1.9 TDI 130 quattro estate with 85k on the clock.
    I booked the car in for a clutch as it was slipping top end. Whilst it was in I decided to have the DMF done too because I felt as if the clutch pedal was really rough. I also provided the garage with a clutch bearing sleeve (genuine audi) as I thought this may be worn causing the rough pedal. Anyway, it's still not cured...800 quid later! It's really spoiling the drive of the car. If the engine is off the pedal is lovely and smooth. Sometime pressing the pedal is smooth whilst the engine is on but is especially worse when driving. It's noticeable when pressing the clutch pedal and disengaging it. I can feel the engine vibrating basically through the pedal. Now I know it's NOT the clutch and flywheel as they're literally a week old and have been replaced with quality OEM parts and the problem was there before and after. Also the thrust bearing and sleeve were also replaced.
    Searching google and forums there are masses of stuff on the DMflywheel but eliminating this, is it possible I am feeling a vibration from another common problem....the alternator clutch? I have noticed vibrations and rougher feeling in the clutch when I am parking the car in a tight spot, say parallel parking and have full lock.
    What's your thoughts? I have had a few 130 pd engined golfs but this audi is being spoilt by this issue..any help/advice appreciated. thanks..Daniel
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    Engine mount or gearbox mount?
    I believe VCDS can flag up if its the engine mount on the nearside. Look for leaking fluid
    A4 1.9TDI Sport - 130 (B6) / Mods: None yet, just getting the basic right first
    Apr 2013
    Quote Originally Posted by scottshere View Post
    I have had the yellow check engine light on the last couple of days but no leaks.
    READER84's Avatar
    Jan 2013
    237
    I get the same issue on my B7, but no warning lights, someone suggested flywheel but looks like thats not the case!
    READER84's Avatar
    Jan 2013
    237
    Anyone shed any light on this ?
    Greeny233's Avatar
    Mar 2011
    Llangollen
    703
    Follow Greeny233 On Twitter Add Greeny233 on Facebook Add Greeny233 on Google+ Visit Greeny233's Youtube Channel Visit Greeny233's Instagram Channel
    The only thing I can think of is the bearing is faulty, it's not unheard of. My friend who owns a garage has a few every year, I've even seen a faulty DMF this year as well but that made a horrible grinding noise when the car was started, that was on an A3.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
    READER84's Avatar
    Jan 2013
    237
    Quote Originally Posted by Greeny233 View Post
    If its the bearing does that mean a whole new clutch?
    alpesh26's Avatar
    Mar 2011
    271
    If you mean the release bearing, they're around £15 from euro car parts but the labor will bring the cost up. I changed my clutch when I got my B7 because the release bearing kept on making a quack noise when releasing the clutch when it was warm.
    Audi A4 B7 1.9TDi SE | Auto Lights, Wipers & Dimming Mirror | Cruise Control | DIS
    Mod's so far: Ambient light, Cupra R splitter, 4300k HID's, Painted Brake Calipers & Hubs, Dice Electronics iPod & Aux, Leather Armrest, Interior, Sidelight & Number Plate LED's, Curry Hooks, Tie Downs, Ambient Footwell LED's, Footwell Lights, Shadow Chrome S-Line (RS6) wheels, Mudflaps, Votex Rear Diffuser, RS4 Rear ARB
    Greeny233's Avatar
    Mar 2011
    Llangollen
    703
    Yes the clutch release bearing. You can buy them separately.
    READER84's Avatar
    Jan 2013
    237
    How much labour is involved in changing a bearing? Is this confirmed as being the fix to it?
  1. Help ! clutch pedal is dead...
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd February 2014, 15:57
  2. Vibration through clutch pedal
    By grey99 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th August 2006, 22:42
  3. Clutch pedal vibration
    By Griffter in forum Diesel forum
    Last Post: 6th January 2006, 18:06
  4. clutch pedal vibrating
    By imported_kris_tdi in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th September 2004, 21:12
  5. 1.9 TDI Serious Clutch Pedal Vibration
    By matt_splatt in forum General Technical / How To
    Last Post: 13th April 2004, 22:53
