Volks AutosJMB Retrofits
    Mar 2011
    Chester
    167
    High Mileage S4 - experiences needed?
    I'd really appreciate any experiences of high mileage S4's? High mileage being 120k plus and what have your experiences been in terms of faults and costs of repairs?
    I currently own a 2.5tdi Quattro and I'm aware of the common faults of the B6 (glovebox / plenum drains / wing rust etc) so I'm more interested in engine issues.
    I've changed job and have gone from driving 20k to 6k per year which means I can stomach the MPG/Insurance of an S4 but I could really use some real life experiences from you guys.
    I'm aware of the timing chain rattle issue and will only buy an example that has a full history and where any chain rattle dissapears after 10 seconds.
    I've seen a few posts reporting problems with alternators & susppension arms.
    If anyone in the North West fancies taking me for a drive in their S4 to help me appreciate what a good one performs like then i'd be very willing to provide a few beer tokens to cover inconveniences & costs. I plan on buying a good one, treating it well, and enjoying it for a good 5 years +.
    Looking forward to your responses.
    A4 (B6) 2.5TDI QUATTRO SPORT AVANT
    Dec 2006
    barnsley
    1,012
    ive had my s4 for 7 years now so have quite a bit of experiance with it
    in all it has been a very very good car
    be wary of the timing chain issue , but also be aware there are several companies at the moment working on a permanent fix which will let the s4 go on for years and years
    if the rattle does not go away within the first second or so not ten seconds then leave it well alone
    the standard exhaust is very very restrictive and many owners opt for swapping it for an aftermarket system such as milltek
    this will release a little bit of the roar you expect with a v8
    by now the car should have had its coil packs replaced on the audi improvement scheme , if not book it in at an audi dealer and have the coil packs replaced for free
    steering wise the upper and lower arms can suffer bushing problems on higher mileage examples
    brakes there are plenty of options available to replace and prices are resonable , beware any s4 which doesnt brake well as the standard brakes are awesome
    servicing wise audi,s reccomendation for long life oil is 0w30 for normal use its 5w30 or higher temperature climates 5w40
    a lot of the american cars run 5w40 but over here 5w30 is spot on .... ALLWAYS USE FULLY SYNTHETIC
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Dec 2006
    barnsley
    1,012
    cam cover gaskets can leak and are a pain to change due to the location of the back bolts
    the front engine mount has a tendency to fall to bits and some owners replace with a slightly harder aftermarket rubber compound
    the auxillary belt may need swapping as this is the thing that drives the alternator
    id advise you change the tensioner as well when doing do
    evidence of some or all of these things being done will be a good sign
    i wouldnt be too worried about full dealer service history , more so evidence that the maintenance has been done and done correctly
    such as reciepts for the parts themselves not a tick in the book which says "yes" thats been done
    Mar 2011
    Chester
    167
    Thanks for that. Really useful. Yes, I'd rather find an honest example that's had common faults put right or have them sorted out myself. I'm not really one for 'modding' so will be looking for a fairly standard one. Having said that, how much are Milltek systems? I heard one a few months back, it sounded amazing.
    Dec 2006
    barnsley
    1,012
    depending on which milltek option you put on they run from around 800 upwards to close to 2.5k if you replace the front cats also with sports cats
    some millteks sports cats have been known to fail very very early also so be awre of this
    most people go for cat back systems either resonanted or non resonated
    the resonated has an extra box in between the front and back boxes .... lets the power out but keeps the noise out of the cabin
    the unresonated has no extra box and is straight through gives a great throaty sound but can also drone inside the cabin
    its not uncommon for air con pumps to go faulty , power steering is generally not a problem however early on audi advised most owners to slightly overfill the expansion bottle due to warning lights coming on
    both air con and power steering are driven directly off the timing chain as is the oil pump , the alternator is driven off the auxillary belt
    Dec 2006
    barnsley
    1,012
    if you buy a tiptronic make sure the gearbox oil fluid has been changed every 60k .... even through audi say its sealed for life no oil lasts forever ... after audi america tested the oil for a customer the american audi dealers now reccomend changing it !!!!
    this is an expensive job as it can take upto 9 litres of fluid to change it and the last time i looked it was £33.00 per litre
    also change the filter and seal while your at it ...roughly £400 in parts before you start with the actual work
    BUT when done the gearbox shouldnt give any trouble whatsoever
    also look for evidence of the rear diff oil being changed also again around 60k
  1. High mileage A3's?
    By StanboA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd July 2004, 23:45
  2. High Mileage 1.8T Quattro Help Please
    By imported_allisons in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th June 2004, 12:55
  3. After advise on a relatively high mileage S3..
    By SideShowBob in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th December 2003, 09:23
  4. High mileage chip?
    By cbass in forum Tuning
    Last Post: 5th December 2003, 14:15
  5. High Mileage 1.8T
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2003, 12:52
