Chris NottVolks Autos
Thread: oil leak help
    hitman1978's Avatar
    Apr 2012
    castleford
    105
    oil leak help
    Hi, today I changed a load of stuff on the car, injector seals, intake manifold gasket, dipstick tube,oil cooler breather elbow and flushed the coolant. Thought I'd finally found my oil leak when I changed the breather elbow which was in bits but when I came to put the bellypan back on noticed oil allover the front end of the engine, anyone any ideas as to what could be causing this leak?
    A4 b6 1.8t 190 sport Quattro avant revo stage 1
    Mar 2013
    oil leak help
    Rocker cover gasket! I haven't had my car long. But have come across most of the common faults already. Was told not to bother with after market one and went straight to TPS. Was only £12. Then put a dab of trv sealer in corners.
    hitman1978's Avatar
    Apr 2012
    castleford
    105
    Forgot to menton, did the rocker gasket about a month ago,
    Jun 2011
    Great Melton Norfolk
    1,340
    Have you tried cleaning the front of the engine to see where its coming from?
    hitman1978's Avatar
    Apr 2012
    castleford
    105
    Yesterday decided to try and clean the engine up a bit, seems to be coming from the turbo side of the block, no leaks from turbo feeds but its caked wot looks like a pump with a corrugated breather hose directly below the turbo. Can't see whereabouts its coming from tho
    hitman1978's Avatar
    Apr 2012
    castleford
    105
  1. Oil Leak - Help Please
    By Red-Eye in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th June 2011, 13:42
  2. 2.0 TDI OIL LEAK!!!!! HELP NEEDED!
    By A3Alice in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st January 2010, 00:40
  3. Oil return line oil leak Help.......
    By S3 Dave in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th June 2009, 21:59
  4. oil leak HELP PLS lads
    By khalil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd December 2008, 19:46
  5. OIl Leak - Help Please
    By cbass in forum General Technical / How To
    Last Post: 20th September 2004, 20:29
