AH FabricationsEM Tuning
Results 1 to 10 of 10
    tbs
    Nov 2012
    44
    Towing ( sorry to slow the traffic down a bit)
    Any other caravan towers who can help...I need advice on 2 things:
    My avante is 1.9tdi 130bhp SE and not lowered in any way. I think it would benefit from firmer dampers at the back and maybe all round. But which ones would marry up well to current springs. Secondly... reversing the caravan really heats the clutch fast ( it stinks) so if a replacement becomes necessary becuase of accelerated wear could I fit an uprated DM clutch without costing a fortune. How much should I pay to have standard clutch fitted all in and is it a dealer job or can any garage do it? What are the pitfalls?
    Jul 2007
    London
    3,074
    Try and stop riding the clutch on reverse and you should not have any problems ! You can get the clutch and flywheel fitted for about 600 all in at a specialist- that's what i charge !
    FOR SALE:
    Oct 2009
    Hull
    1,433
    Re: Towing ( sorry to slow the traffic down a bit)
    The clutch is burning because of the brake on the caravan is there not anyway you can lock it for reversing?
    Oct 2009
    Hull
    1,433
    done a bit of research for you
    apparently after around the 70's caravan brakes only work on the over run when going forwards if the brakes are coming on when reversing there is something wrong
    tbs
    Nov 2012
    44
    The caravan brakes are definitely not on. Its hard on the Audi with its reverse gearing to go to a slow enough crawl speed fully engaged Ill try to avoid slip but I think its easier said than done. £600 for a clutch gets close to the price of caravan moving device which I guess takes some of the wear away. My drive has a mild ramp to start with and i have to reverse and turn and I'm pushing about 1200kg plus gravity and thats when it overheats. Would uprated clutches still wear as fast with my tendency to slip it.
    Apr 2012
    N. Wales, LL22
    1,224
    don't give it any gas at all, use the power at idle to move it, the anti stall will add more power as needed*
    *up to a limit, you may have to add power as a last resort
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    tbs
    Nov 2012
    44
    i've changed my Audi parts temp sensor and still without towing my temp is 70 degrees. When towing and under load it rises to 90 degrees and will cool down again if i cruise down hill. Now if i change the thermostat will I see temperatures of 110 under load or will a new thermostat reduce the higher limits. I suspect it wont and is it ok to have higher temperatures when towing.
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    533
    The thermo should put the engine in a stable condition,once warmed up (15mins of driving) the temp will be comfy 90 and stay there. Under most driving conditions.
    1.9 avf 6 speed. Bv43 turbo. Swifttuning custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    tbs
    Nov 2012
    44
    Id like to change the thermostat myself but I cant see how...I cant see it or get my hands to it and it looks a right pain (assuming its at the end of the lower hose behind the alternator buried deep) is that where it is on the 1.9tdi? Ive read one thread about it but that doesn't really reassure me. Any body else got some practical help i can use.
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    A 10mm socket and and extension bar is all that's needed! And a 50/50 mix of G12 anti-freeze (pink) and de-ionised water to top up your coolant. Simples!
    A4 Avant 1.9 TDi Sport GmbH
  1. For all your FWD boys that want to get the power down.... Droop limiters
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2010, 18:12
  2. Slow moving traffic...?
    By lil_coz in forum Jokes, Games & Humour
    Last Post: 13th May 2008, 01:05
  3. Moving The Aircon Down! !!
    By Mcgough in forum In-Car Entertainment
    Last Post: 24th November 2004, 23:20
  4. Sorry, here is the pic of Audi Body Kit??
    By Ari2002 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th February 2004, 10:33
  5. Have the drop downs gone?
    By dbm in forum Site Support & Announcements
    Last Post: 10th December 2003, 13:33
