Monster MotorsportChris Nott
    Nov 2012
    9
    Audi '3212' tool / alternative for alternator removal
    Hi guys,
    My alternator has packed in, so as usual I went at it without doing my homework. Got the top bolt out, can't get the bottom one out, need to take the fan off, can't.
    Done some research and need a '3212' tool to hold the pulley while I crack the bolt holding the fan.
    Any suggestions on where to get one or make a DIY alternative?
    Thanks.
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    368
    I changed one of these yesterday at work you need an 8mm allen key to undo the bolt holding the fan pulley from behind and I used an oil filter removal tool to hold the pulley so to not damage the pulley and it worked perfectly
    8K xenon upgrade-LED side lights-LED number plate bulbs-Apex springs-B5 perches-Votex front & rear valance, side skirts, roof spoiler-LED Fog re-wired as DRL's-DRL's wired as see you home lights-Rear lights tinted-centre box removed-4" tail pipes-LCR front splitter-Spacers Front18mm Rear19mm-S4 door blades-RS4 style grill-B7 aero wipers-K sport 8 pot caliper 356mm 2 piece discs - 19x8.5 Cades Apollo wheels-De-chromed roof bars and window surrounds-Engine bay tart up-Window tints-RS4 rear ARB
    Nov 2012
    9
    Thanks mate I appreciate the reply. I assume you mean a sort of tool like this and not the chain type? As I would have thought the chain might damage the pulley?
    Halfords | Halfords Advanced Professional Oil Filter Removal Band
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    368
    Very similar but mine has a rubber strap but that will work, you would need to release one side of the strap on that tool to feed it round the pulley and reconnect and tighten up to hold it
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    368
    another way I've done it before is using an old aux belt cut it and feed it round the pulley bring the two side together so it's tight round the pulley then with a pair of vice grips clamp the 2 sides together using the vice grips as a lever you can hold the pulley tight, this way works too without damaging the pulley
    Nov 2012
    9
    OK buddy I get the type you mean now - thanks for the help!
  1. What alternator for AFBs?
    By PAULF in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th January 2012, 13:48
  2. alternator/fan belt removal 2 tdi blb engine
    By andy16vturbo in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th March 2010, 16:23
  3. Uprated Alternator For Audi A4 B5
    By ZeroK66 in forum In-Car Entertainment
    Last Post: 27th December 2006, 19:33
  4. Audi V8 rear differential for audi A4!
    By Coolberg in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2004, 21:14
  5. Garage using your audi when its in for a service??
    By Chimera in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2003, 09:34
