Chris NottMonster Motorsport
    bitnics's Avatar
    Oct 2012
    Bristol, UK
    159
    Engine Fault Codes Need Help 17546 and 17544
    Hey guys,
    My EML is on and the fuel consumption is poor. I already replaced all the vacuum pipes and vapour valve and still no luck.
    Did any of you guys had this fault code? How did you solve it?
    Engine is 2.4 BDV.
    Code:
    17546 - Fuel Trim: Bank 2 (Add): System too Lean
                P1138 - 001 - Upper Limit Exceeded - MIL ON
    17544 - Fuel Trim: Bank 1 (Add): System too Lean
                P1136 - 001 - Upper Limit Exceeded - MIL ON
    Thanks for all your input.
    "Audi A4 the benchmark 4 seater cabriolet" - Top Gear
    A4 Cabriolet 2.4 Sport | Atlas Grey Metallic | 6-speed Multitronic | 170 BHP | Twin Exhausts | BOSE | Navi+ RNS-D | Playstation 2 | 6 CD Changer | S4 LCD DIS | Black Pearl Nappa | 35W 8000k HID’s | Roof/Windows Up & Down With Key SmartTOP | Folding Mirrors |
    My build thread:
    http://www.audi-sport.net/vb/project...storyline.html
    Twitter: @jakewylezek
    Apr 2012
    202
    I would check to make sure you have no air leaks in the system anywhere. Even something like leaking exhaust manifold gaskets could cause a too lean figure. Also what are the air and fuel filters like? Been changed recently? If these are blocked it can cause air or fuel starvation.
  1. Replies: 14
    Last Post: 16th January 2013, 20:47
  2. 2.5 tdi engine fault codes help please...
    By Kostas in forum VCDS (formerly VAG-COM) forum
    Last Post: 18th June 2011, 02:53
  3. MULTIPLE FAULT CODES! NEED HELP PLZ!
    By seen_ in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd November 2010, 13:33
  4. Fault Codes,need help
    By L3WJX in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2010, 23:55
  5. 2 fault codes found? Help/Advice needed.
    By AidenUK in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th February 2010, 19:14
