Badger5EM Tuning
Thread: Radio fail
    Mar 2013
    Radio fail
    I've just got into my 2002 A4 and the stereo won't come on? And when the ignition is off stays illuminated. Any ideas?
    Jun 2003
    World of my own
    9,813
    You need to check both fuses, there is one in the fusebox and one on the back of the stereo.
    It will most likely be the one on the back of the stereo if the illumination still works
    The radio stays live with the ignition off, it doesn't shutdown until the keys are pulled out
    Alex Turner
    Mar 2013
    Radio fail
    Nice one. I'll have a look after work and let you know the outcome.
    Mar 2013
    Radio fail
    All sorted. Nice one. Thanks.
    Oct 2009
    Hull
    1,442
    if it was a popped fuse then you need to check out why it popped they dont just go for no reason
    Mar 2013
    Radio fail
    It had just come loose in the fuse box. Thanks.
  1. Problem with standard Chorus radio on my S3
    By JasonM in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th November 2004, 18:01
  2. radio security code
    By bredhurststeve in forum In-Car Entertainment
    Last Post: 31st October 2003, 14:15
  3. Urgent! Radio Question
    By pilotboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th September 2003, 10:21
  4. stuck radio
    Last Post: 24th September 2003, 12:56
