Badger5Chris Nott
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    Garrett Turbo Rebuild Kit
    Has anyone used one of these or similar?
    Garrett Turbocharger Turbo rebuild / repair service kit GT15-25 GT1749V | eBay
    I'm assuming my Avant 1.9 TDi 130 turbo is as old as the car, 146k, so would I see any benefits from carrying out a turbo clean and rebuild? I have already done a Mr Muscle clean and have had no problems with the car in the 6 months I've owned it. I will soon have the car on the drive way for a week to carry out a full service and timing belt change, amongst other things, and I'm thinking while I've got the front off that the turbo will be easier to remove too. I will also be giving my intake system a good clean.
    My thinking is that the turbo seals, bearings etc are subject to wear just like any other on the car so should therefore be serviced occasionally. Is this sound reasoning or should I stick to the "if it ain't broke, don't fix it" mantra when it comes to turbos?
    TIA
    Adam
    Oct 2009
    Hull
    1,440
    I would say you are wasting your time on something like that
    first of all it will need balancing plus if you have any wear where the bearings sit this would need re grinding/building up so it was back to spec
    if you want it doing then send it off to someone who can do all this
    Sep 2012
    Swindon
    371
    Didn't know it would require balancing afterwards. Thanks for that
    Oct 2009
    Hull
    1,440
    yup it needs to be spun up to about 22,000 rpm!!
  1. VNT Turbo rebuild
    By bdub in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th March 2008, 16:59
  2. Backdraft Big Turbo Base kit
    By Backdraft Motorsport in forum Tuning
    Last Post: 16th January 2008, 10:50
  3. Turbo Rebuild/Repair ?
    By eastside_valver in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd December 2006, 21:34
  4. Anyone know about garrett turbos........
    By The Slug in forum Tuning
    Last Post: 1st July 2006, 23:25
  5. Turbo/Supercarger kits for 3.2
    By Eeef in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th March 2006, 07:00
