Volks AutosBadger5
Results 1 to 17 of 17
    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    Multitronic gearbox behaviour
    Recently (like last weekend) we bought my wife a 2001 B6 2.0 avant with Multitronic, on the test drive all seemed ok, but my wife reported that it seemed jerky the other day, not being into cars that was the best description she could give me. So, I took it for a drive to see what she was talking about, at first I couldn't really feel any jerkiness as such, just a bit hesitant as it was stone cold which pretty quickly cleared, but a bit further into the journey I came to a junction where I had to come to a stop, when it was clear I proceeded but there was a pause in movement, almost like it wasn't in gear and then all of a sudden it julted forward and pulled away as normal.
    Sometimes it does this when you come to a stop and other times it can pull away nice and smoothly (like I expect it should) but most of the time it does this odd pause and then almost violently jults forward on pull away. When on the move it changes gear seamlessly and all other functions like kick down and tiptronic mode work fine.
    I know it's different to a conventional auto box as it has a multi plate clutch and a DMF, and it's also electronically controlled, but would that really make it behave this way?? I used to own an E46 SMG2 M3 a couple of years ago which effectively has the same sort of gearbox but that never did anything like this and was alway dead smooth on pull away.
    If anyone has experienced the same thing with their Multitronic I'd much appreciate any input as to what could be causing it and a solution, or if anyone has any ideas as to what it could be that would be great.
    Could it just need adjusting with setting on VCDS??
    Thanks in advance,
    Az
    B6 A4 2.5 V6 TDi Quattro Sport
    Dolphin Grey I 210 BHP Remap I KW V1 Coilovers I 19"x9.5" all round BBS LM reps I RS4 Anti Roll Bar Kit I S4 Front and Rear Bumpers I Votex side skirts I S4 Aluminium Mirrors I S4 Rear Spoiler I S4 Style Tailpipes I USDM S4 licence plate blank I 6000k HID's I 18 SMD DRL's I Cupra R Splitter I Full RS4 black leather with white stitch optional bucket seat interior I RS4 black headlining I TT S Line FBMFSW I Aluminium Trim I Reverse camera I Full DIS I Cruise Control
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    639
    Re: Multitronic gearbox behaviour
    Same thing happens at times on my brothers 2006 Passat with DSG. When engaged in reverse its like as you said and when it goes it jerks.
    Mechanic says it could be most likely box related or electric. Although I did sense that he is confused by the problem.
    Jul 2007
    770
    Has it had the ATF changed?Mines a tiptronic drives smoothly and I believe yours should be better if its healthy
    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    Thanks for the replies.
    It has had a ATF change last year, think it was in July when it was changed, got the receipt and it was ATF from Audi so is the correct stuff. I only know that because I thought the same thing last night so went through it extensive pile of receipts.
    Does it have a hydrolic pump or electronic pump for engaging the gears? Or at least for engaging 1st or reverse?
    Jul 2007
    770
    Diagnostics might help.Was the ATF change by Audi?
    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    ATF was done at a place called Cars-tech, looking them up on the net they are a German car specialist, I have a receipt for the gearbox oil from Audi, the previous owner bought 8 litres of it but there is another receipt for returning 2 litres of it, so it looks like up to 6 litres of oil we're used for an ATF change, is that right? Seems a lot to me, from previous experience the most I've ever had to buy for a gearbox oil change has been about 3 litres, and the mrs car is only FWD.
    Mar 2013
    Near Oxford
    406
    They do take a lot of oil mate. Might be worth phoning a cvt specialist to see if they can diagnose the fault, could be an early warning of something failing. There is a specialist in Bristol that seems to have had a few good reviews. Hope it is nothing serious.
    Jun 2011
    Great Melton Norfolk
    1,356
    They do take that amount , take 9 litres if they change oil in torque converter.
    Have a read of this ,
    http://frankensteinmotorworks.com/tu...ultitronic.pdf
    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    Yeah cheers guys, hopefully nothing serious. It doesn't throw an engine or transmission light on or anything so not sure if it would be holding any faults, will have to invest in VCDS like I've been meaning to for god knows how long!
    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    Quote Originally Posted by gen.heinz guderian View Post
    Thats some serious bedtime reading mate!! Very interesting though! Didn't realise they were such a complicated gearbox, which worries me slightly!.....
    Jun 2011
    1,356
    You can buy most of the parts separately, Solenoids, chains,valves pretty much anything .
    Audi will say you cannot though. The Oil is special too as it lubricates the final drive as well as is expensive. Make sure they used the right one.
    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    Well as said the ATF was bought from Slough Audi, it doesn't have the chassis number or registration on the receipt but the part number for the ATF is - AG 052 180 A2, can anyone confirm if that is the right fluid for a Multitronic box?
    Jun 2011
    1,356
    yes that is right for a multitronic box
    Jun 2011
    1,356
    You could get it scanned with vcds it may show up a fault. The vw 09a box said little or no communication when the high clutch pack was failing on my Golf.
    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    Thanks for your help mate, appreciate it. I'll have to see if anyone in or around my area on here has VCDS to scan it for me for a few sherbets as I don't have the funds to buy VCDS myself just yet.
    _G_
    _G_'s Avatar
    Jul 2011
    869
    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    Quote Originally Posted by _G_ View Post
    Thanks very much for pointing me in the direction to that link mate, very interesting. I'll definitely be doing the wheel sensor clean and checking for moisture or water in or around the gearbox wiring loom and passenger footwell today. I took the car for a decent drive yesterday and it's not 'that' bad, if you drive it carefully and allow the gearbox a little bit of extra time at junctions it's fine, but in situations where you need to pull out quickly out of a junction it's far from smooth and can pretty violently jult forward when pulling away. Hopefully the wheel sensor trick works, I'll report back once I've done it!
  1. multitronic gearbox
    By purplecatqueen in forum General Technical / How To
    Last Post: 19th April 2009, 10:43
  2. New User - Multitronic Gearbox Question Please.
    By audi fan in forum The Welcome Section
    Last Post: 5th February 2009, 21:00
  3. multitronic gearbox
    By JR6 in forum General Technical / How To
    Last Post: 9th January 2008, 20:50
  4. Multitronic Gearbox
    By terrysingh in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th September 2007, 20:31
  5. HELP multitronic gearbox!!!!!
    By Spannertail in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th April 2007, 16:55
