AH FabricationsChris Nott
    gtvlew's Avatar
    Mar 2013
    SWANSEA,WEST
    65
    Unclipping S line front fog lamp grille surround advice required
    Morning all, as above really, these are the grille types i have on my 190 bex see pic, i'm looking at fitting Hella or Phillpis DRL's, do they clip off from the front or do i need access from behind ? cheers Gary
    Mar 2008
    1,054
    just give it a pull and it comes off
    gtvlew's Avatar
    Mar 2013
    SWANSEA,WEST
    65
    Quote Originally Posted by vr6gordy View Post
    Thanks mate
    Dubbers1's Avatar
    Top Gear
    Jul 2011
    Bedfordshire
    228
    Sod that, those little clips you see (2 at the top and 2 at the bottom) just need popping up with a flat blade screwdriver, then it'll slide out
    Audi A4 1.8T S-Line Quattro (190) '04
    VCDS HEX-USB+CAN
    Mar 2008
    1,054
    Quote Originally Posted by Dubbers1 View Post
    as its cold then maybe do it that way yes plastic might break
  1. A4 B7 S line front fog surrounds
    By carl-1968 in forum For Sale/Wanted - Audi Parts
    Last Post: 27th June 2012, 18:35
  2. Front fog lamps
    By TOON FLYER in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 9th May 2011, 21:48
  3. Removing fog lamp grills
    By tku in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th January 2010, 14:13
  4. fog lamp grill removal
    By JustCharlie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st January 2009, 21:13
  5. a4/s4 lower front fog lamps wanted!
    By imported_jack0811 in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd July 2004, 09:34
