AH FabricationsChris Nott
    czm
    Feb 2013
    209
    Crankcase Breather Valve Woes
    Hi all
    To day I replaced the CC breather valve on my 2004 1.8t Avant with 70k miles.
    Below you will see my concerns, there was alot of white/yellowish mayo in the pipe and in the valve.
    My main concern is the sludge issue with these BEX engines however there was no real sludge just this horrid mayo gunk. Of course cleaned the pipe and fitted the new valve and the car runs well now.
    However I was wondering what precautions/actions I shoudl be doing to keep everything clean and breathing well? Shall I replace the rest of the breather pipes ect and if so what bits do I need ect?
    Anything I can use to flush it while all in place?
    2004 BEX 1.8T Silver Avant - RTECH Stage 1 Remap - 211Bhp/236ft Torque
    TEIN Super Street Coilovers - BlueFlame Catback with 4'' Slashed/Rolled Tips
    Pipercross AirFilter- RS6 18'' OEM's - 225.35.15 Falken 452
    Mar 2012
    185
    Clean out the rest of the breather system at the top rear of the valve cover and also to the left of the valve cover. You may find that it will be worse the the crank valve, specifically the metal pipe attached to the left of the valve cover.
    Plenty of threads about it on here, think I may have written something about when I did mine.
    czm
    Feb 2013
    209
    Quote Originally Posted by duffy78 View Post
    Great thanks
    I have read loads about certain parts of the system that break and become brittle. Which bit shall I look at buying before I start to save any down time?
    Mar 2013
    Near Oxford
    351
    Standard for these engines. I had a oil catch can fitted to my last 1.8t, it certainly helped.
    Mar 2012
    185
    The parts that I replaced were the pcv, the rubber pipe that the pcv fits in, the rubber elbow that goes from this pipe to the oil filter housing and also the hockey puck shaped valve at the back of the engine.
    The part that was brittle and deteriorated was the elbow to the oil filter housing.
    Just get yourself plenty of 20 and 30cm jubilee clips as the hoses are held on by one time only clips.
  1. Crankcase Breather Valve Location
    By CHRIS555 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th August 2013, 21:46
  2. Crankcase Breather Valve
    By czm in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd March 2013, 13:07
  3. Where to buy a crankcase breather valve for 1.8t
    By duffy78 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd February 2013, 07:55
  4. crankcase breather valve thingy, part number?
    By hitman1978 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th July 2012, 22:54
  5. 2.5TDI crankcase breather
    By Graze in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2005, 17:32
