Monster MotorsportEM Tuning
Results 1 to 8 of 8
    Smillie13's Avatar
    Sep 2012
    West Lothian
    933
    Follow Smillie13 On Twitter
    2nd Gear Problem
    Don't know if this is a serious problem or not but every now and again my car refuses to go into 2nd gear, its fine in all other gears. Its happened about 4 times since September and only lasts for a couple of journeys then disappears again. Any advice much appreciated.
    Thanks in advance Susan
    Here for a good time, not a long time
    x Susan x
    Feb 2013
    9
    could be a worn gear linkage or might have a bit of dirt in the linkage that gets stuck at the secong gear point sometimes and gets dis lodged again and then gets lodged back in again from bumps in the road ,,,
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    Worth trying a transmission oil change. What's your running gear and mileage?
    Smillie13's Avatar
    Sep 2012
    West Lothian
    933
    Quote Originally Posted by doodah View Post
    Car is an A4 1.9 TDI Avant and everything is standard on it - mileage is 125k
    x Susan x
    Sep 2012
    Swindon
    371
    I best go see Audi then and get my 'standard' shark stage 1 map uploaded!
    Your gearbox has certainly done enough mileage to warrant an oil change. Close scrutiny of any drained oil should also give an indication as to any potential issues. I have actually changed mine twice recently. Put some off the shelf stuff from ECP and if felt terrible afterwards so I ended up using this stuff instead Halfords | Castrol Syntrans Multivehicle 75W-90 1L and it feels much better now!
    If you give me your gearbox code from your service sticker, I'll check that the castrol stuff is indeed the correct oil for yours and give you a little how to guide.
    Smillie13's Avatar
    Sep 2012
    West Lothian
    933
    Ok apart from the stage 1 lol - anyway engine code is HCF
    Thanks for the little How To its appreciated
    Susan
    x Susan x
    Sep 2012
    Swindon
    371
    Same gearbox as mine so that's easy!
    With a warm engine/gearbox, jack the front of the car up and remove the two under-trays. Hopefully, you can identify the gearbox from here, and locate the drain plug underneath and the fill plug on the right hand side (both a hex key bolt but I don't recall the size). UNDO THE FILL PLUG FIRST! If you drain then can't fill then you're screwed! Now drain just as you would for engine oil so leave it draining and go and have a brew. In your case, have a good look in the drained oil for anything that could be causing you problems.
    Now for the filling (after refitting the drain plug, ensuring it's clean). My first attempt at this was messy to say the least! As it's a side fill it's a little tricky getting the oil in there. By the time I came to my second attempt, I'd had a brainwave. Get one of these 5L LITRE MANUAL KNAPSACK GARDEN PRESSURE SPRAYER SPRAY KILL WEEDS | eBay (available from the likes of wilkinsons and the range too) and remove the spray handle leaving just the rubber hose. You'll find that this hose fit nicely into the gearbox. Do this by feeding the hose down from the engine bay so your then not working underneath. Drop the car back onto LEVEL ground and put a small amount of the castrol oil into the sprayer (check it's free of any crap before starting) and start pumping. Hopefully, the oil should start transferring into the gearbox. If any is dripping out, you need to feed the rubber hose further into the gearbox and try again.
    The stated capacity of the gearbox is 3 litres of oil which is, essentially, fill to spill. Once full, jack up again and refit the fill plug. Both the fill plug and drain plug should be tightened to 45Nm, which I found to be approximately 4 white knuckles . You should then take the car for a quick spin then check the level again ie level with housing at the back of the fill hole (difficult to see but the photo shows what you're looking for and why fill to spill is the way forward...you can't see the oil because of the tricky access!).
    I have yet to get round to doing this part yet but will be checking it in a few weeks while doing some other work, but the gearbox has felt good ever since.
    That's it! Now I'm not saying this will cure your problem but, seeing as a replacement gearbox will be brewster's, approx £40 doing an oil change is definitely worth a shot!
    Good Luck!
    Smillie13's Avatar
    Sep 2012
    West Lothian
    933
    Thank you again - i will let you know how I get on
    Suxan
    x Susan x
  1. A6 C5 1.9 tdi 1st/2nd gear problem
    By RizlaUK in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 17th January 2012, 21:02
  2. 1st and 2nd Gear problems after clutch change!
    By trophs in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd October 2011, 21:26
  3. Gearbox Problem - Lost 1st/2nd Gear!
    By deano_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd April 2008, 08:46
  4. A3 tdi 1st / 2nd gear selection problem
    By davidelson in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th November 2007, 07:41
  5. 2nd gear problems !
    By danneth in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th September 2006, 08:15
