Monster MotorsportVolks Autos
Results 1 to 9 of 9
    Nov 2011
    South Lanarkshire
    75
    Oil warning light
    Hi all. On my way home from work this morning I had a yellow oil can come up on my dash display saying sensor.
    I immediately stopped and checked the oil level which was fine.
    Anyone any ideas as to the cause of this ?.
    thanks M
    Jun 2011
    130
    if the levels ok it would just mean you have a faulty oil level sensor, just keep an eye on it and swap out the sensor on the next oil change
    nothing to worry about !
    Nov 2011
    South Lanarkshire
    75
    Thanks boomtown, I'll get one ASAP. I'm nearly due an oil change, so ill do it sooner rather than later. Might even pop into ECP tomorrow as I also think I need a brake light switch.
    m
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    Euro car parts have a 25% off offer online, ends today!
    Nov 2011
    South Lanarkshire
    75
    thanks doodah, but I cant find the part online.
    Sep 2012
    Swindon
    371
    GSF do them, if you have one nearby, but no discount
    Nov 2011
    South Lanarkshire
    75
    Hi doodah, I got one at ECP but as they don't list it on their website I couldn't get discount. But I got the 25% off everything else. Still spent over £120 on parts..
    m
    Sep 2012
    Swindon
    371
    Bummer! At least you got discount on the other bits you needed though
    Mar 2013
    83
    Make sure you get the right one, look under the car the possibilities are two identical part numbers, the last digit is 'B' or 'C' pretty sure tha a ones are pre-b6, the 'C' one has a C in the cooling fins/casting, the B one does not.
    got mine off eBay for about £28 posted.
  1. OIL WARNING LIGHT BUT PLENTY IN????
    By veccyj in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th December 2007, 12:07
  2. 98' A3 Oil Warning Light
    By 1.8TCraig in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd February 2007, 19:14
  3. Resetting The low oil warning light.
    By Biggles in forum General Technical / How To
    Last Post: 19th January 2007, 09:08
  4. 2.0 16v coupe oil warning light
    By andy64 in forum Classic Audi Forum
    Last Post: 29th June 2006, 22:50
  5. Oil warning light Min
    By imported_ashs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2005, 20:46
