Badger5Sky Insurance
Results 1 to 8 of 8
Thread: Manual??
    Sep 2005
    Portsmouth
    29
    Manual??
    Hi,
    Is there a 'Haynes' type manual for the B6 A4?? Also is the top section of the doorcard removable, or is it one piece??
    scoTTy's Avatar
    Essex, UK
    1,958
    Re: Manual??
    Is this what you're looking for?
    http://www.bentleypublishers.com/product.htm?code=AB65
    I'm not sure it covers the FSI engine though.
    Jun 2003
    World of my own
    9,813
    Re: Manual??
    The whole door card comes off in one piece. Unclip the plastic trim piece prise it off from the back and work towards the front.
    This reveals a load of screws, remove these and the one at the bottom in the centre and the whole thing lifts up & off (easier with the window down).
    Unclip the wiring looms. Be careful when refitting as the main wiring loom will clip back in & look OK but inless you've pushed it all the way in (it's quite a tight fit) before closing the retaining clip it won't make any of the electrical contacts (this caught me out)
    Sep 2005
    Portsmouth
    29
    Re: Manual??
    I ordered an ElsaWin pack off ebay, and i must say i am very impressed!! It is very comprehensive and easy to use. With great diagrams, pictures, etc. Well worth the money IMO.
    imported_bubstar
    Re: Manual??
    I got one of these a couple of weeks ago but I'm having problems installing the data discs. I need to do a re-install at home I think .......................................
    Can't wait to get it going though
    arthurfuxake's Avatar
    Controversial & Contradictive
    Mar 2004
    Manchester
    1,306
    Re: Manual??
    [ QUOTE ]
    [/ QUOTE ]
    I had the same problem. Ended up copying the data discs onto my laptop hard-drive, then copying the data over the network to my desktop hard-drive and doing an install from hard drive. Worked perfectly. The first data disc would not read properly in my DVD drive on the desktop machine.
    imported_bubstar
    Re: Manual??
    Thanks for the tip - The seller's been quite helpful but I'll have another go...........
    BUB [img]/ubbthreads/images/graemlins/ok.gif[/img]
    Sep 2005
    Portsmouth
    29
    Re: Manual??
    I couldn't load data disc at first!! Tried again and it worked ok. Very impressed!!!
