Results 1 to 7 of 7
Thread: Help !!!
    gtvlew's Avatar
    Mar 2013
    SWANSEA,WEST
    65
    Help !!!
    Locked car on fob about 2 hrs ago, knock on door neighbour tells me car alarm going off very quietly with hazards flashing aswell, went to konock it off on key fob Nothing happens, tried spare keyfob still same, unlock car with key alarm still going, started car ok all hazrds and siren stopped.
    both fobs not working, locked car on key, 30 secs later same again lights flashing and siren very quiet.
    I aint got a clue !!!! regards Gary (car is bex 190 quattro)
    Andie0's Avatar
    Aug 2012
    487
    Quote Originally Posted by gtvlew View Post
    Have you tryed messing with the buttons in the pocket in the drivers door?
    2004 audi a4 s line 1.8t bex 242bhp dynoed
    Mods: bsr optiflow kit, forge diverter valve, custom turbo back exhaust, custom 200 cell cat, DGR coilovers, forge tip, s3/tt 386cc injectors, boost gauge, revo stage 2, 12mm rear spacers, rear window extension spoiler
    To come: big brake setup... Getting there!!
    boats and hoesss, boats and hoesss
    gtvlew's Avatar
    Mar 2013
    SWANSEA,WEST
    65
    No just locked the car on the fob earlier this evening and now this has started
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    I would open the bonnet, lock all doors on the car, disconnect the battery, and deal with it tomorrow in the light if you can
    *WANTED* AUDI CD PLAYER
    gtvlew's Avatar
    Mar 2013
    SWANSEA,WEST
    65
    Right i found this and it works a treat, the only problem when ive programmed the first fob, when i swap the fobs around to program second one after the second fob is programmed the 1st fob stops F********g working arghhh!!, so ive got my main fob working now but the spare does not. this is info i found
    1. Take the spare key, put it into the ignition and turn the key to the "on" position, just prior to starting the car.
    2. Roll down the driver's side window (not required, but a good idea in case there's a problem).
    3. Exit the car and close the door.
    4. With a second key, physically lock the doors (don't use a remote).
    5. Take the first remote to be programmed, press one of the buttons and the lights will flash once. Wait 10 seconds and press the unlock button. The doors should unlock. That first transmitter is now programmed
    gtvlew's Avatar
    Mar 2013
    SWANSEA,WEST
    65
    will try this in the morning for second key
    gtvlew's Avatar
    Mar 2013
    SWANSEA,WEST
    65
    Could'nt wait till morning both fobs now working very strange why it happened in the first place
  1. Help! Need a new coilpack!
    By SteveS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2003, 22:29
  2. I.T. help please!
    By MisterD in forum General Chat
    Last Post: 20th January 2003, 21:19
  3. Please help, my hard drive has disappeared !!
    By sidicks in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 17th January 2003, 15:43
  4. Help Wanted - Amusing slogan
    By Moresauce in forum General Chat
    Last Post: 13th January 2003, 01:18
  5. Banner AD include help????
    By Administrators in forum General Chat
    Last Post: 7th January 2003, 15:21
