JMB RetrofitsVolks Autos
Results 1 to 18 of 18
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Question S4 ARB or RS4 ARB?
    In relation to fitting to a TDI 130 Avant Sport, which would you folk recommend?
    Do both the S4 and RS4 need new brackets, and can you get these with the bar?
    *WANTED* AUDI CD PLAYER
    Nov 2006
    cardiff
    88
    use the old brkts ,just need new bushes , get an rs4 arb , much better !
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    368
    Fitted the RS4 to my Avant a month or so back, top mod.
    I wouldn't even consider the S4 one over the RS4 It's not as if the RS4 one is expensive,
    go for it, it makes a very noticeable difference to the handling.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,680
    RS4 rear anti-roll bar, all the way. Works a treat on B6 and B7 models, especially the V6s.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Does it increase the work that the rear tyres and suspension have to do?
    Dec 2011
    Wales
    106
    If your going to make the most of the better handling you will have with the RS4 arb then sure you will be giving your tyres especially a harder time as for the suspension...not really. Use your old drop links unless they are showing signs of wear, you will need new brackets and bushes due to the increase in diameter. Worth all the effort.
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Good info guys.
    Do the S4 and RS4 have seperate brackets?
    Jul 2007
    London
    3,247
    The overall size of the brackets is the same between the diesel, s or rs models ! it's the internal diameter of the bush that's different and as above rs4 all the way ! I have it on a FWD 1.9 tdi which crapped it's gearbox after a big power hike, it made it handle really like a quattro in the dry ! Still no substitute for the quattro in the wet !
    FOR SALE:
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    The sport models have very little body roll anyway, I still get the feeling that the 22mm bar would be too stiff
    Dec 2011
    Wales
    106
    Quote Originally Posted by DALE_AVANT View Post
    NO and double no, the quattro sport has some body roll with the RS4 arb fitted the balance between stiffness and roll is perfect, you turn into corners with added confidence. Try it if you don't like it there will be plenty of takers on this forum alone who would buy it off you, but I bet you won't sell it!
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,157
    Do it - I fitted my RS4 ARB along with coilovers and new front suspension arms - will never look back. Handles great for an estate!
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    Dec 2006
    barnsley
    1,019
    i changed mine on my s4
    gave me better turn in as a result which was good , but on the downside it doesnt change direction as fluidly as it did before
    make the anti roll bar too stiff for the rest of the car and there will be consequences
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,576
    RS4 on my Sport and works a treat. Make sure you get the matching bushes and larger clamps with new bolts as my bolt were corroded badly.
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,680
    Yes, but they still have lots of understeer, which the 22mm RS4 anti-roll bar will reduce considerably.
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Living in Milton Keynes, tyres get a harder time due to all the roundabouts, hence I am still erring towards the S4 bar to allow for this
    Andie0's Avatar
    Aug 2012
    487
    Can i ask off what year rs4 do i need to get for my b6? I wont to do this mod right as have been putting it off but am readu to buy and am going to tps this week want to get it all thanks
    2004 audi a4 s line 1.8t bex 242bhp dynoed
    Mods: bsr optiflow kit, forge diverter valve, custom turbo back exhaust, custom 200 cell cat, DGR coilovers, forge tip, s3/tt 386cc injectors, boost gauge, revo stage 2, 12mm rear spacers, rear window extension spoiler
    To come: big brake setup... Getting there!!
    boats and hoesss, boats and hoesss
    Dec 2006
    barnsley
    1,019
    it needs to be from the b7 andieo
    the mod increases turn in , but as a consequence reduces rear grip coming out of the corners
    Andie0's Avatar
    Aug 2012
    487
    Thanks mate i will be getting one! Well i best not do any lift off oversteer coming out the corners then ai lol
  1. Front RS4 ARB ON A 2.0 TDI ,Is it worth it?
    By fozworth in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th September 2010, 23:01
  2. Would an RS4 ARB fit onto a B6 A4 3.0 Cab?
    By Solani in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th September 2009, 19:15
  3. RS4 ARB on 3.0TDi Avant
    By blackwood in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th July 2009, 21:07
  4. S4 ARB's or RS4 ARB's
    By arthurfuxake in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st August 2007, 17:21
  5. S4 ARB's or RS4 ARB's?
    By arthurfuxake in forum Handling
    Last Post: 21st August 2007, 10:11
