JMB RetrofitsEM Tuning
Like Tree2Likes
  • 2 Post By N11KDJ
Thread: Cleaning MAF sensor on 1.9TDI
    Aug 2004
    67
    Is there a guide on how to clean the MAF sensor somewhere ? I've had a look but can't see anything, I've got some electrical contact cleaner today, do I need to remove the whole thing or just take the sensor out if the plastic tubing & clean that on its own?
    Any help much appreciated..
    2004 A4 Avant Sport TDI..
    audilad9's Avatar
    Jan 2013
    Highlands
    257
    Pull off air duct that channels air to filter housing.
    Unplug MAF sensor using small flathead screwdriver.
    Using a torx bit with indent (hollow end) undo 2 screws holding MAF in place.
    Remove MAF and give it a good spraying with the contact cleaner until clean.
    replace, refit screws, plug, duct.
    Aug 2004
    67
    Cheers for that, I took the whole maf housing off and sprayed thoroughly inside , hopefully that'll have cleaned it ok, I think I've found the problem now anyway, boost pipe not connected properly.
    audilad9 and m4tty like this.
  1. can maf sensor be cleaned or does it have to be replaced??
    By 4rings in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th April 2011, 21:17
  2. Cleaning MAF sensor
    By nick4501 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2011, 18:16
  3. MAF MAP sensor readings 1.9TDI
    By Family Wagon in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th June 2010, 13:24
  4. MAF sensor cleaning
    By jiffi77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2005, 10:26
  5. Help please - 1996 A4 1.8T MAF sensor cleaning ?
    By philwest in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th March 2004, 23:59
