Volks AutosChris Nott
    ab6
    Mar 2013
    Cab roof problems
    Hi guys new to the forum sorry to start with a fault but I have bought a Quattro Sport Cab (2003) with a roof fault. The roof retracts as you would expect until one of the roof bars catches on the front part of the storage compartment. This prevents the roof folding completely away. It all appears straight & lines up perfectly when you put the roof back up. Not sure how to remedy this and have searched for any previous problems to no avail.
    Jan 2011
    687
    Can you post a pic of when it is about to catch ?
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
    ab6
    Mar 2013
    Thanks for the quick reply... Will post a pick tomorrow.
    ab6
    Mar 2013
    P1040489.jpg Point where it gets stuck. Roof bar is catching on the metal above storage area.
    P1040490.jpg Side view at same point.
    Thanks in advance.
    Jan 2011
    687
    Hard to say exactly but if you mean it s hitting the bit right behind the rear seats it looks a bit like the whole roof mechanism is slightly too far forward. If you look on youtube there are some good quality vids of the roof opening , might be worth a watch to see how the positioning matched yours.
    davidfox280585's Avatar
    Aug 2009
    108
    Is the rams opening the back cover enough? The rams could be weak or hydraulic pressure low due to low fluid level the pump is located on the osr corner behind radio amp,you cannot fit the roof out of line I've fitted 3 now
  1. A4 Cab roof problem....HELP!!!
    By ridgy666 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th September 2012, 20:24
  2. Audi A4 Cab roof problems PLEASE HELP
    By geordie944 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd April 2012, 11:50
  3. cab roof problem
    By bowen in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th September 2011, 10:56
  4. Hello from a 09 plate A3 cab owner with roof problems!!
    By Filthygorgeous in forum The Welcome Section
    Last Post: 17th April 2009, 21:11
  5. 2002 A4 Cab roof trouble
    By gdcfc in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th July 2003, 10:55
