Volks AutosAH Fabrications
Results 1 to 9 of 9
    Mar 2012
    163
    Can anyone help - possible wheel bearing failing.
    As I'm driving it sounds as if my front drivers side (i think) wheel bearing if on its way out.
    There is a whining sound when I'm driving, I can hear it clearer when I'm cruising. As my speed increases it seems to get louder and higher pitched.
    Is there anyway I can check the bearing to make sure that it is that or I have the correct one.
    cheers,
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Jack it up and spin the wheel mate to listen for the grind..
    Mar 2012
    188
    If you turn left and the noise gets louder it's the right bearing and vice versa.
    May 2012
    RETFORD, NOTTS
    1,753
    does it get louder on left hand bends when the wieght is on the bad wheel?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Nov 2012
    bath/windermere
    27
    iv got the exact same problem at the minute, the noise starts around 20mph and gets horribly worse as I pick up speed although it only disappears when I turn left ! iv been quoted £30 for a bearing and 2 and half hours for the labour ! don't suppose you know how easy it is to do your self do you?? did my mechanic course 6 years ago and not really touched a car since lol
    Aug 2011
    199
    Take a look at the first page of Rob Morris' current thread on his 2.5 - the info there might help? Mike
    Dec 2011
    Wales
    106
    I'ts not a bad job, make sure you have the correct torx tools. The four bolts holding the bearing can be tough to undo, I had to use heat on my bolts to undo. You also need a vice a big lump hammer and large socket to hammer the bearing out and new one in.
    Mar 2012
    163
    Thanks for all the replys guys ill get my car up at weekend.
    Mitch18 - where did you get the quote for £30 for the bearing, I have only seen on Ecp for £80-&120
    Dec 2011
    Wales
    106
    Quote Originally Posted by Harribo66 View Post
    Ebay!
  1. B5 Tsq Ronal Bolero 17" wheel Wanted....Can anyone help???
    By eyeball in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th February 2012, 17:34
  2. Can anyone help even audi failed
    By liquids3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th June 2011, 15:23
  3. Can anyone help me out? Need a locking wheel nut socket.
    By Slinger in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th April 2010, 08:35
  4. Replies: 1
    Last Post: 31st July 2009, 01:20
  5. Getting knocks even at idle! Can anyone help?
    By imported_RastaS4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th August 2004, 09:47
