AH FabricationsSky Insurance
Thread: anyone know if
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,947
    anyone know if
    this part nimber will work instead of this
    this was water damaged 8EO 907 279 C central electric modual
    should this work ? same number diffrent end letter 8EO 907 279 B
    pluged the B unit in and it keeps sidelights on when trying indercators it flashes the side lights fast
    no fault codes etc
    TIA
    Apr 2012
    lincs
    202
    no fault codes etc
    TIA
    My car is an 02 but 03 model year and it has the 279c unit in it.
    The parts catalogue lists 279d thru g the difference being d isn't listed for DIS (but mines a C and DIS works!)
    1 8E0907279D
    onboard supply perform. module
    (1) 8E0907279E
    onboard supply perform. module / for vehicles with driver informationssystem -fis- / F >> 8E-3-191 155*
    / AVANT
    (1) 8E0907279E
    / sedan
    (1) 8E0907279E
    onboard supply perform. module / for models with day driving headlights / F >> 8E-3-191 155*
    / sedan
    (1) 8E0907279E
    onboard supply perform. module / for vehicles with driver informationssystem -fis- / F 8E-3-191 156>>*
    (1) 8E0907279E
    onboard supply perform. module / for models with day driving headlights / F 8E-3-191 156>>*
    / PR-8K1,9C6
    (1) 8E0907279F
    onboard supply perform. module / for models with automatic day driving headlights / F >> 8E-4-110 000
    / PR-8K3,8K7
    (1) 8E0907279F
    onboard supply perform. module / for models with automatic day driving headlights / F 8E-4-110 001>>*
    / PR-8K7
    (1) 8E0907279G
    onboard supply perform. module / for models with automatic day driving headlights / F 8E-4-110 001>>* / relay plate / PR-8K3
    A 'B' unit should preface a C and usually the later units are backwards compatible.
    Have you looked at adaptation and coding - as the unit you are putting in could be coded for lights, etc.
    Ross-tech (b6):
    Audi A4 (8E) Central Electronics (8E2/8E5) - Ross-Tech Wiki
    though the B7 has additional codes:
    Audi A4 (8E) Central Electronics (8EC/8ED) - Ross-Tech Wiki
    cheers
    And
    A4 2.5 tdi Q sport '02 AKE, "minor modder", 18x8's S4 Avus , Zender Monza's 18x8.5's, aero wipes, interior trim, dis and cruise, real s4 mirror caps, rns-e led, dble din, VCDS owner-learner - GMBH next
    bez101's Avatar
    Jul 2008
    7,947
    yes iv coded it
    to what it was before
  1. Anyone Know?
    By melman in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2008, 09:52
  2. Anyone know this car??
    By Anito in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 6th May 2004, 17:02
  3. Anyone know the exact alloy fitment I need.
    By Newbie123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th April 2004, 10:43
  4. Anyone know this S3 (B6 RON)
    By dik in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th January 2004, 14:41
  5. Babies and S3s. Anyone know of a good importer?
    By MushroomMan in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2003, 17:05
