Monster MotorsportBadger5
    bob2312's Avatar
    May 2011
    Failsworth Manchester
    42
    Key fob ,can I check if signal produced
    Am having problems yet again ,have replaced batteries in both fans and tried the recyncing methods ,is there any way I can check if a signal is being produced ,I know if you use a remote for a tv near a radio it produces interference is there anything similar I could do, have had a a previous issues with broken wires in the drivers door which have been fixed but told the module in the door might need replacing as no signal is sent to display to show if it is open,remote worked to open car but when I tried to lock nothing ,if it is the door module any idea of cost my car is a 2001 2ltr se saloon ,thanks,realise that the remote uses a radio frequency just wondered if it produces interference that could be noticed
    Danny-boy's Avatar
    Jan 2013
    477
    Best way to test a TV or other remote of that type is by looking at it through your mobile phone camera.
    It can see the IR. pretty cool really.
    Don't think it works on car remotes though as I think they are radio frequency based.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,530
    nice 1 just been trying all my remotes
    dont work on car remote tho
    bob2312's Avatar
    May 2011
    42
    Well after retrying one of the fobs is now working will just keep playing with other I know I did something with unlocking door or locking whilst holding one of the buttons ?
    Oct 2009
    Hull
    1,442
    insert key in to ignition and turn it on press lock and unlock remove key and it should work
    If no joy open the fob and bend the battery pins to make sure you have a good contact
    bob2312's Avatar
    May 2011
    42
    Used car last night no probs unlocked car this morning short 5 min drive and nothing took key apart checked terminals all ok ( bugger ) any ideas out there
  1. Remote Key Fob
    By macca666 in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2006, 07:05
  2. Key and Key fob
    By imported_Cali in forum Detailing
    Last Post: 14th December 2005, 21:21
  3. key fob total closer
    By ALISDAIR in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th October 2005, 22:27
  4. Can someone check my car please
    By belabed in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2005, 19:45
  5. 2 Button Key Fob
    By recomdos in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th May 2005, 20:14
