Chris NottSky Insurance
    nickb834's Avatar
    Oct 2010
    40
    Auxilliary radiator delete?
    So - my B6 S4 has a leaking o/s auxilliary radiator and the n/s doesn't look like it's too far behind.
    I'm loathe to spend 150 quid on a radiator and then have to replace it again in a couple of years.
    I had the bumper off this weekend to sort out a snapped alternator belt (swapped tensioner and idler too) I took a good long look at the aux rad - I'm inclined to bypass the rad and remove it - much the way that some people have on the B6/7 S4/RS4 so they can fit a cold air intake kit.
    What I'm thinking of is a pipe with two 90 degree elbows - for the same overall length as the distance between the two outlets on the rad, where the elbows have the same internal and external diameter as the rad outlets.
    Has anybody on here done this - got any tips, where to source elbows and hose for example?
    Dec 2006
    barnsley
    921
    there is a specific kit avialable from the u.s
    i would not simply bypass the rads as one of them is actually to control oil temperature and with it deleted you may well overheat the oil
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    nickb834's Avatar
    Oct 2010
    40
    Quote Originally Posted by dualmono21 View Post
    You sure about the oil, because there's a separate oil cooler on an S4? (there was on my B5 but I can't recall for sure on a B6?).
    I saw the JHM kit - but it's not really worth the expense, the import duty etc - particularly as I have no interest in fitting a cold air intake.
    That said it's a moot point as I've managed to get an offside radiator from Leeds audi for trade price - Audi UK even had 3 in stock so it's here tomorrow.
    I'm thinking of cutting an inch and half gap in the air duct that butts upto the rad, so that leaves and crud etc can drop down instead of clagging up at the bottom of the rad like it did in mine:
    Hopefully it'll at least stop any corrosion - won't do much for stones etc.
    Dec 2006
    barnsley
    921
    yes mate quite sure
    the jhm kit replaces the d/s one with a mocal oil cooler which mounts directly to the block
    when i had my bumper off there wasnt much crud or **** in there but i did manage to spray the rads with sprayable copper slip
    this should hopefully weather protect them against anything being lodged in there
    might be worth doing the same while your doing the job
  1. New A3 auxilliary air heater
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th April 2004, 23:38
  2. Audi 90 CS Radiator fans quit
    By jlmata in forum Classic Audi Forum
    Last Post: 2nd June 2003, 15:19
  3. Radiator Crisis
    By faene42 in forum Classic Audi Forum
    Last Post: 29th May 2003, 02:17
  4. Thread deleted
    By Administrators in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th January 2003, 13:42
