Chris NottAH Fabrications
    Mar 2013
    14
    Trim/carpet removal & boot problem..
    I posted earlier re "03 avant niggles' but the trail went cold, hence new post..
    1. Can anyone tell me how to remove the passenger door pillar trim to pull the carpet up, in order to dry it & check that the comfort module box isnt soaked ( is it direvtly under the passenger feet carpet btw?)
    2. Boot release - once you get access to it, is it possible to activate the boot release & see if its sliding acroos with the boot up & open?
    Thanks.
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    2. no - I don't think you can see the boot solenoid activating with the boot open.
    LostBok/BahnStormer77
    Mar 2013
    14
    ..apparantly you can..although it just seem to move on the boot release button.
    Unfortunatley although it moves it still doesnt unlock the boot when it is re-closed...I can see the pin sliding but it only moves fully on occasion other times, despite being lubed, it only moves partially.
    I did find a spade connector unconnected hanging from the back of the accutuator - how many 'wires' should it have?
    Dec 2006
    barnsley
    934
    the trims on both passenger and drivers side a pillar simply pull off theres also one slightly higher in the door jamb which if its fitted correctly should interlock with the upper and lower
    check the footwell under the passenger side seat as thats where the pipe for the rear wash wiper runs and if it has a leak this is where it tends to go
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Mar 2013
    14
    Thanks for that...figured it out eventually myself late sunday!
    Any clues about this 'spare' connector off the boot actuator?
  1. How to remove A3 boot trim - with photos
    By Fleagle in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th November 2013, 22:36
  2. Rear Footwell Lights/Door Trim/Carpet Removal - Routing Wires
    By Silky-S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th January 2012, 16:32
  3. b6 Avant boot trim piece removal - access to wiper
    By Jimmeh in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th March 2010, 00:12
  4. Boot trim/sub removal
    By AndyMac in forum In-Car Entertainment
    Last Post: 8th February 2006, 12:55
  5. S3 Boot problem...help needed...
    By Austin in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2004, 23:39
