Volks AutosJMB Retrofits
Thread: Oil leak
    Alan H's Avatar
    Need a V8 or Bi-Turbo.......
    Aug 2010
    Dudley, West Midlands
    453
    Oil leak
    Hi all,
    I have a small oil leak coming what looks to be around the back of the oil filter, could this be the gasket on the oil filter housing causing it?
    Ta,
    Alan
    Alan H's Avatar
    Aug 2010
    453
    Does anyone know which gaskets to order to cure this problem?
    Thanks,
    Alan
    Oct 2009
    Hull
    1,442
    bit hard to say from the vague description
    pics would be good
    Alan H's Avatar
    Aug 2010
    453
    The oil leak is definitely coming from the underneath of the oil filter / housing . The filter is tight. I dont think putting a picture up would help much because looking at the oil filter from above you just see the filter. The only evidence of the leak is seeing oil down the side of the engine underneath the filter. There are no external signs of damage, no oil seeping out from on top of the filter, nor can i see any on the oil cooler above it at its split line, so I can only assume an internal gasket or "o" ring has given up. I'm really trying to as retain which one of these internal seals (for want of a better word) has or may have given up the ghost, and order the parts from the stealers accordingly.
    Thanks,
    Alan
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    Have a look on vagcat.com
    It's not guaranteed to be 100% accurate but should give you some ideas
    Mar 2011
    Truro, Cornwall
    62
    I have a small leak from the same place but haven't had chance to look into it. I just assumed it was the filter a bit loose. It has only appeared since I changed it.
  1. Oil Leaked
    By langtonr in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2006, 23:48
  2. OIl Leak - Help Please
    By cbass in forum General Technical / How To
    Last Post: 20th September 2004, 20:29
  3. Oil Leak 4 days after i bought car
    By imported_andrew74 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2004, 12:28
  4. Oil leak found after having car at dealers
    By ianburtney in forum General Technical / How To
    Last Post: 14th June 2004, 08:19
  5. Oil Leak found after having car at dealer
    By ianburtney in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th June 2004, 08:16
