EM TuningBadger5
    Mar 2013
    N. Ireland
    7
    TIGHTENING HANDBRAKE ON 2001 A4 1.9TDI
    HI ALL, JUST WONDERING IF YOU CAN HELP ME WITH TIGHTENING MY HANDBRAKE.
    I RECENTLY CHANGED THE PADS SO OBVIOUSLY NEED TO TIGHTENING UP A BIT, I KNOW YOU HAVE TO TAKE THE WHEELS OFF AND PUT SOME KIND OF SPACER IN SOMEWHERE. THE THING IS YOU HAVE TO DO SOMETHING WHERE THE UNDERNEATH WHERE THE HANDBRAKE IS. DO I HAVE TO TAKE THE WHOLE CENTRE CONSOLE OUT TO DO THIS, WHICH MEANS TAKING RADIO AND AIRCON UNIT OUT??
    HOPE YOU CAN HELP
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    254
    When you changed rear pads - did you wind the piston bore back into the caliper? You can release the brake bleed nipple at the same time and open the brake fluid reservoir cap. Check the return springs on the caliper - they're known to seize so won't take up the remaining tension on the handbrake. Check these first before trying to adjust the cable.
    With the pistons screwed in on both sides - then self adjust them by applying the handbrake a few times. Should be a lot tighter.
    AudiWorld Tech Articles
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    Mar 2013
    N. Ireland
    7
    Hi thanks for the reply,well i managed to get to the release button under the handbrake without takin console off, but found a problem at the brake itself. Yeh i checked the return springs and oiled them up, but one side is still not returning properly,bout 5-10mm space, it really sounds like the cable is catching sumwhere,well i actually do no this as i took the cable of and the arm completely return itself,so spring is fine. I guess its time for a new cable, which definately does mean taking the whole centre console off ffs. This is my first audi, and they dnt seem to make things easy!!
    2,159
    You would not be able to fit new pads if the piston is still sticking out.
    From looking at elsawin the adjustment can only be done with the center console remove, it also quotes the the following.
    The rear brakes are self-adjusting, so the handbrake does not require adjustment in normal operation. Re-adjustment is only necessary after renewing handbrake cables, brake calipers, brake pads or brake discs.
    Also switch CAPS LOCK off...
  1. Replies: 4
    Last Post: 6th November 2010, 19:29
  2. Removing Injectors from 2001 1.9Tdi
    By connaco in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st September 2009, 10:57
  3. Tightening the handbrake
    By denzelburner in forum Diesel forum
    Last Post: 30th April 2009, 22:58
  4. a4 1.9tdi x reg 2001 cooling system riddle
    By yendall24 in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th January 2009, 07:30
