Monster MotorsportChris Nott
Results 1 to 7 of 7
    RyanJonS4's Avatar
    Drive It Like You Stole It
    Mar 2009
    Oldham
    287
    2 quick questions
    Where is the port to plug a fault code reader in on a b6 S4?
    Do coil packs just pull straight out or do i need a special tool?
    my car sounds like its running on 7 and was passing a gsf today so bought a coilpack, and I have an old fault code reader that I used to use on my 8l a3 which I presume will work on my s4?
    Ryan
    Milltek non-resonated cat-back - 15mm MTM spacers - Toyo T1R's all round - RS4 Pedals+foot rest - Blackout model front grilles - Custom black front badge - de-badged boot - R8 oil cap - silver indicator bulbs - Dodo Juice supernatural wax - ECS tuning Porsche cayenne brake kit ready to fit or sell?...
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,429
    under the dash above your right knee
    and yes pull out
    bez101's Avatar
    Jul 2008
    8,429
    and iv had trouble b4 with gsf coilpacks
    i always go dealers or TPS for any sensors packs etc
    Mar 2009
    470
    Has your S4 had the coil pack recall? If not speak to Audi.
    Bez is right about the location of your OBD port.
    B6 S4 4.2L V8 Cabriolet Black Manual Quad Milltek Non Res
    RyanJonS4's Avatar
    Mar 2009
    Oldham
    287
    Not sure if it has had the recall tbh but ive owned it since 2007 and it hasnt in my ownership.
    Is there any way of telling?
    I've only bought this coil to get me by until I find out if it has/hasnt had the recall. If it has then I will have to buy 8 new off audi and fit them which will be a 30 mile round trip I didnt fancy on 7 cylinders. If it hasnt had the coils done it would still be 15 miles 1 way which I presume wouldnt do it any good?
    Ryan
    Mar 2009
    470
    Iirc all 8 of my coil packs were replaced about 18 months ago, I think that is about the time they were doing the recall. As you have owned yours since '07 I would say you haven't had the recall done. Give Audi a call or drop in to your local dealership , service is normally open until 12 on a Saturday.
    I think they have a look at the coil packs and check the serial or part numbers on each one to see if it needs replacing. They might be able to squeeze you in for a quick check and then at least you know where you stand.
    Mar 2009
    470
    Are you with a recovery or breakdown service. You might be able to get them to trailer recover you to Audi. Emphasise you dont think it is safe to drive it to Audi and they will recover you. It has to be a trailer though as you cannot tow a quattro.
    If you havent got breakdown cover and you want to replace the coil pack if it is a coil pack that is at fault, you would need to scan for codes to tell which cylinder coil pack is causing you the problem. There are plenty of how to's on changing coil packs on the internet and forums.
  1. Quick Question about Aircon/Climate Control
    By DelBoyUK in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th July 2004, 17:37
  2. A quick question on N75??? Valve
    By simondavidr in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2004, 21:31
  3. quick question
    By richy in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2004, 10:46
  4. Quick Question
    By cbass in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th January 2004, 16:42
  5. Quick question about Audi a4 coilover kit
    By anwar in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th May 2003, 22:13
