AH FabricationsEM Tuning
Results 1 to 20 of 20
    cookiesvw's Avatar
    Sep 2012
    88
    A4 cabriolet rear window
    My drivers side rear window has decided its not going to go all the way down. Can anyone help. ?
    bitnics's Avatar
    Oct 2012
    Bristol, UK
    159
    Edit: Sorry it's the rear one! I had similar issue sometimes it will just not react. But restart the car then use the "all-windows" switch and readjust it and back to normal.
    What happens when you press the button? Any noises? Depends if the line snapped or the window switch is not getting any voltage. Check for errors with VCDS sometimes it can flag something.
    Look on my build thread. There is a link to a window repair kit.
    "Audi A4 the benchmark 4 seater cabriolet" - Top Gear
    A4 Cabriolet 2.4 Sport | Atlas Grey Metallic | 6-speed Multitronic | 170 BHP | Twin Exhausts | BOSE | Navi+ RNS-D | Playstation 2 | 6 CD Changer | S4 LCD DIS | Black Pearl Nappa | 35W 8000k HID’s | Roof/Windows Up & Down With Key SmartTOP | Folding Mirrors |
    My build thread:
    http://www.audi-sport.net/vb/project...storyline.html
    Twitter: @jakewylezek
    cookiesvw's Avatar
    Sep 2012
    88
    I can operate the rear window but it stops 3/4 of the way down leaving 1/4 of window sticking out.
    bitnics's Avatar
    Oct 2012
    Bristol, UK
    159
    It sounds like it skipped some of the closing/opening cycle and has to be readjusted.
    My build thread:
    cookiesvw's Avatar
    Sep 2012
    88
    Do you know how to do this. Will disconnecting the battery for ten mins then putting back on reset the system.
    Danny-boy's Avatar
    Jan 2013
    477
    I thought you just got the window to the top and keep holding the switch up for 10 seconds.
    Resets the motor or so I'm told.
    Worth a try though anyway.
    cookiesvw's Avatar
    Sep 2012
    88
    Danny. Just tried that and nope no luck. Lol
    Jan 2011
    687
    I think it's drop it all the way down and hold for 30 seconds then all the way up and hold for 30 seconds.
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
    cookiesvw's Avatar
    Sep 2012
    88
    Still no luck :/
    bitnics's Avatar
    Oct 2012
    Bristol, UK
    159
    Did you run a scan with VCDS?
    On another note my roof won't open.
    My build thread:
    Jan 2011
    687
    Roof manual reset procedure maybe ? There are vids on YouTube.
    bitnics's Avatar
    Oct 2012
    Bristol, UK
    159
    The locks are not being open in the window frame. Open circuit.
    My build thread:
    cookiesvw's Avatar
    Sep 2012
    88
    Vcd ?? Not sure if this was aimed at my window. It's been sooo cold I've not tried disconnecting my battery but not sure this is gonna work.
    bitnics's Avatar
    Oct 2012
    Bristol, UK
    159
    It should pick up a fault code usually if you could get the DTCs out with VCDS.
    My build thread:
    cookiesvw's Avatar
    Sep 2012
    88
    What's the dtc ? And vcd sorry to sound thick.
    bitnics's Avatar
    Oct 2012
    Bristol, UK
    159
    VCDS is a diagnostic software and interface. DTC = Diagnostic Trouble Code.
    Battery disconnect technique here probably won't help. Make sure you got your radio code before you do that.
    My build thread:
    cookiesvw's Avatar
    Sep 2012
    88
    Like vag com?
    O yes need to look for radio code just incase. Blooming cars
    bitnics's Avatar
    Oct 2012
    Bristol, UK
    159
    My rear right windows plays up sometimes and VCDS picked it up. Below I pasted my DTC. Try to scan yours.
    Yes you can say Vag-Com and VCDS are pretty much the same although VCDS is the latest product.
    Code:
    00935 - Electric Window Motor; Rear Right (V27)
    62-10 - No or Incorrect Adjustment - Intermittent
    My build thread:
    cookiesvw's Avatar
    Sep 2012
    88
    Had it on vcds and both rear windows were out of sync. All reset and working fine.
    So much better they go all the way down lol.
    cookiesvw's Avatar
    Sep 2012
    88
    And the suns out today so won't look silly with one window sticking up a bit.
  1. Cabriolet rear window needs resealng....:-(
    By carl_turbo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd May 2012, 20:32
  2. Removing the rear window wiper...
    By imported_trident21 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st January 2005, 14:48
  3. Rear windows on A3
    By imported_mwilliamson88 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th December 2004, 14:03
  4. HELP!! Heated rear window and wing mirror problem
    By tboy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th November 2004, 14:14
  5. 80 Cabrio Rear Window
    By Melwoods in forum Classic Audi Forum
    Last Post: 25th August 2004, 22:26
