Badger5Chris Nott
    JasonS's Avatar
    Feb 2012
    North Herts
    90
    2.5TDI Glow plugs replaced
    My Cab has been reluctant to start in the cold recently and has been producing clouds of white smoke.
    It has started every time, but I suspected the Glow Plugs needed refreshing.
    I sprayed on some penetrating oil on Friday, then again on Saturday when I dismantled enough to get good access to the plugs. I had read about them breaking, so took it slowly and carefully. They were all very tight, but came out successfully. I had a bit of trouble getting one back in.. It didn't want to screw into the thread, I ended up screwing one of the old ones back in and out before the new one would go in.
    I cleaned out the inlet pipe as well, I didn't have the time to clean the manifolds and EGR valve, I'll maybe get to that another time.
    My wife came out with a cup of tea and I showed her the sooty gunk in the pipes. She said I shouldn't expect an improvement as the kettle gets scale in it and that doesn't stop it from working.
    It's been flipping cold and with the new plugs it starts immediately with no smoke, so I'm very pleased.ImageUploadedByTapatalk1363043346.285330.jpg
    2005 A4 Sport Cabriolet 2.5 TDI
    Previous Audis:
    1997 A6 Avant 2.5 TDI Quattro
    1994 80 Cabriolet 2.0
    1995 S6 2.2t 20v Quattro
    1998 A6 Saloon 1.8t
    1995 A6 Saloon 2.0
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Lucky git - I done the same the weekend and made no improvment on the starting!
    Ive a new temp sensor on the way with fingers crossed..
    Jul 2007
    770
    Mine has started well since it was retimed by Adamms24(Chris) but I think I would test the plugs before thinking of changing them.CTS should help
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,159
    I changed my plugs a few months ago after similar issues - all of mine were dead! - I made sure I copper greased the thread on the new ones if I need to change them again in the future.
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
  1. 1996 A6 2.5TDi Quattro Estate Glow Plug Problem
    By mmarks in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 20th May 2007, 20:13
  2. 2.5TDI Glow plugs
    By wanstronian in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th August 2006, 18:57
  3. 2.5TDi glow plug problem
    By mmarks in forum Classic Audi Forum
    Last Post: 4th April 2004, 20:16
  4. 2.5TDi glow plug problem
    By mmarks in forum General Technical / How To
    Last Post: 14th March 2004, 11:49
  5. 2.5Tdi glow plug problem
    By mmarks in forum Diesel forum
    Last Post: 29th February 2004, 20:45
