Monster MotorsportEM Tuning
Results 1 to 8 of 8
    Mar 2013
    Angry n75 valve causing limp mode
    I bought an audi a4 sport pd130 2001 then a few weeks later started getting limp mode, plugged into vag com and got back low boost pressure got told to try changing the n75 valve as the turbo was fine only goes into limp mode 3rd or 4th gear when you boot it, I bought the part and had it fitted to find out it was wrong as the part number did not match also not sure if it is the right bit i am replacing. the egr has been blocked not sure if this has anything to do with it, Diesel N75 valve Audi A4 Audi A6 1.9 TDi 2.0 TDi 8E0906627C | eBay this is the part that was wrong this is the part no of the part that come off 8E0906628A 8E0 906 628 A the old one did seem broke as you could blow though both sides of the valve but now im thinking this is the part i need VW/AUDI TURBO BOOST SOLENOID VALVE N75 1.9 TDI | eBay really stuck.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,313
    Welcome to audi-sport.net Mark. Im sure the guys will be able to help you out. Have a read at the faqs threads at the top of the page, lots of useful info in there and a lot of knowledgeable guys on here. Any pics of the car? Where are you located? Enjoy the forum. x
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    Mar 2013
    Mar 2013
    from alnwick northumberland
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,313
    Quote Originally Posted by markjohngray View Post
    thanks for the pic Mark. If you interested in meets/events with other members, click the link below and have a look through posts for upcoming events in your area. x
    1,872
    Someone should be able to answer form this section, but it's a B6 so may get more answer in that section.
    Mar 2013
    could someone move this to b6 please?
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,313
    Moved x
  1. Am i experiencing limp mode/n75 open circuit fault
    By iamramaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th June 2012, 20:34
  2. Limp mode caused by following faults
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2007, 14:52
  3. A3 1.8T power increase trhough N75 valve!!!!!
    By manueltrigo in forum General Technical / How To
    Last Post: 19th April 2004, 10:48
  4. A quick question on N75??? Valve
    By simondavidr in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2004, 21:31
  5. WHATS A ECS N75 VALVE ??
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2003, 12:05
Tags for this Thread
